Mid/top help |
r.G
Registered User Joined: 23 April 2015 Location: Germany Status: Offline Points: 64 |
Posted: 01 May 2016 at 10:51am |
Hello everyone,
I'm planning on building a small soundsystem. Subbass will be covered by scoops, kickbass will be 2x15 reflex. Now the question is, which design and drivers do I use for mids/tops? I was thinking about 2 mids in a sealed box and probably one big horn as a top. But I don't really know what to look for when picking those components. My budget is about 600€ Any help is appreciated
cookie-dj
have a look at my thread http://forum.speakerplans.com/the-beginning-of-bliss-soundsystem_topic92433.html. lots of ideas floated about on it and my almost finished final stack is towards the end
You can't polish a turd!
r.G
I already did, looks really nice and solid! Especially those 2x12" sealed mids, that's the kind of design I'm looking for. But I don't really know what to look out for when designing a sealed cab like that.
1. Is it just a box with a cutout for the driver? 2. Also, 1-2 bullet tweeters or a big horn as a top? 3. Does anyone have a few suggestions (drivers/horns/designs)? Maybe with a short explanation to it (so I can learn something instead of just picking a suggested component ) Also a little bit of information which might be useful: - Roots/Dub/Stepper will be played on it - 2x Super Scooper (Fane Colossus 18XB loaded) - 2x15 BR kick (RCF LF15P380) - Mid/Top amp not picked yet So in summary I'm looking for nice and clear mids and tops on a 600€ budget (at max) to keep up with the scoops/kicks. Building them myself is prefered! Edited by r.G - 01 May 2016 at 1:03pm |
herke
Registered User Joined: 04 November 2009 Location: Huddersfield Status: Offline Points: 171 |
hey cookie, what do you cross your tham12 over at for your 8" drivers?
Also, for your main system (which looks awesome), what sort of crowd would you cover with that?
Cheers |
cookie-dj
The Tham 12 will be running at 50-150ish loaded with PD12SB30. Still untested!
My big system will do a couple of hundred people I shall imagine. Will know more on testing however. |
cookie-dj
Yes I modelled the box to a driver in winisd , tuned the volume to the drivers fs or near enough anyway. It's literally a box with driver cut outs in the baffle. For your tops its your personal preference, reggae systems tend to have bullets or piezo arrays for that extra "sizzle". I chose not to have bullets as I will probably upgrade my comps to the mighty BMS co-ax comp at some point. |
r.G
Ok, can you recommend a driver and possibly a plan for a 2x12 midrange cab?
Also, what do you think about two Beyma CP 22's as tweeters?
Edited by r.G - 01 May 2016 at 3:02pm |
cookie-dj
Literally took me 20 mins from selection of drivers, winisd inputting and 3d modelling on sketchup. Try yourself!
If not, have a look at the fane and eminence cook books, plenty of designs which work with today's drivers. Easily found online |
r.G
I don't have any experience with winisd and only tried sketchup a couple times. Also, don't really know what to look out for when selecting mid drivers. But I'll have a look at those you mentioned!
cookie-dj
Fane sovereign 12 is a fair mid offering if you're on a budget. Plenty of people have used them to good effect. Or maybe something from p audio. Try and speak to Andy from blue Aran on here for budget driver advice. he knows a better range of drivers then a lot of us on here....
r.G
Took a look at them and indeed they're budget. Which frequency should I let them play in? Scoops will be around 30-90, kicks 90-180ish and then? I want to cover everything above that with just two more ways, so 12" (or 10"?) and two more tweeters.
