MIDTOP 15" + 8" + 1" 3 way |
Post Reply | Page <123> |
darkmatter
If you're in the UK drop me a message.
I have 2 x B&C 15NW76, 2 x DE250 and 2 x 8PE21 that are in as new condition and I'm unlikely to be using any time soon as I've damaged my back. |
LeruSound
Registered User Joined: 27 August 2015 Status: Offline Points: 171 |
My ideashas been buit.
Ill upload more pictures or even open another thread if anybody interested! |
gen0me
Nice! How do you cut it? How long are those 15" horn and 8"?
LeruSound
15 inches is around 56 cm long, 8 inches I guess is around 17 cm
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
Awesome! Where did you get the mid/high horn?? VECTORSONICS
dmx256
Registered User Joined: 17 January 2010 Location: Manchester Status: Offline Points: 475 |
Have you considered a 15" plus 10" plus 1"? There's a fair few commercial designs that use this configuration.
Logic System XTA EAW MC2 Robe Anytronics Futurelight Trilite Tas and a wife....
bob4
wow, nice build, didn't notice the pictures until now
LeruSound
I needed the smallest comb.horn possible to fit into the 15 inches horn. It sound good. I had some unexpected results in low part of the 8" speaker reproduction (lot of strange things were happening in 300 -800 hz, dips and peaks around +-5 6 dB.) and i had to higher a lot the 15 inches cutoff freq. The 8 inches i'm using now is almost not fitting in to the phase.p. so i cant imagine a 10 " in any way fitting this config. I was considering to try another model (such as 6ND410 from 18sound) to check if it would have a better coupuling with the throat of that short f.l.horn, but i will see, for now it's ok as it is. Ill' test the copule next days.
Not Smoothed response: Edited by LeruSound - 31 August 2017 at 1:18am |
Hemisphere
Edit: Just seen updated post with pics/plots
Edited by Hemisphere - 31 August 2017 at 1:15am |
LeruSound
Yes nema vented. I tryied for fun and I did a optional back cover with vented port, but then I removed as I didnt need in this case.
CHAMPION
Old Croc Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Try this design..
Sticks n Stones
LeruSound
Man i really can't see the design you are posting, guess the image is corrupted. EDIT: I got what design you are talkin' about. Lot of ppl is giving me that chance as an advice. I really can't uderstand. I saw the design and i followed the developement on the forum. I'ts a good idea, it squeezed out the maximum from two mainfolded 12" and a 2" driver, making possible to cross them. SO: with a good design and a good part of EQing you get the result, in a very compact size. It's a smart and clever design, but it doesnt do the icecream for me & for what is my purpose. i admit it's a very good design, but maybe is not the solution everytime.. I will try, is getting that much popular that a close friend is building now, and for sure he will need me to help him in make them sound so, i will try! Personally i wouldn't choose that design for: - I dont like that much how it looks (ok, but deeply inside you also know it's important :) - I have the idea the two 12" are having difficults reproducing freq. around 1 kHz naturally, because that folds and because of parallel walls in horn expansion. But as always it could easily be well sounding. - I would avoid to use CDs with that low xover, or at least i would avoid a beginner to do so, if it's not a very efficent device, energy could be very unbalanced in music below some tresh. so it's easier to blow up. - you need to be accurate in throat adapting, so easy work outside but a little delicate inside. All the rest of that design is a big big up, very small and easy to travel, and it looks everything is extremely balanced, few components with maximum result. Edited by LeruSound - 09 September 2017 at 11:14am |
