Mini Mid/Tops |
Post Reply | Page <123> |
MarjanM
Yes, horn loading the 6 inches will increase the box size.
bass*en*mass
couple of faital 4" drivers in a vertical row are a simple/cheap
approach to control vertical dispersion to some point (length of the
array) - plenty manufacturers offer similar cabs nowadays..
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
http://www.voltloudspeakers.co.uk/loudspeakers/cx2201/
These volt 8inch coax are stunning, I have some and I think Markie on here has some, well worth a look.
Edited by concept-10 - 22 May 2017 at 10:35am |
MarjanM
For conferences i find horizontal dispersion more critical then vertical when fighting feedback. But yes, 4x4 inch box is plenty easy to make and it will work to some extent.
RosietheBand
Registered User Joined: 30 July 2010 Status: Offline Points: 27 |
Something along the lines of the HK Elements? I've used it in conference situations before and it wasn't too bad! Definitely wouldn't run a band through it, but I had it 6 ft from a lectern mic and it filled a pretty big hall without issues.
Would there be any advantage in going for something like the B&C 4NDF34 over the Faital? |
With love and many thanks,
Rosie. www.rosietheband.com |
RosietheBand
I was looking at these earlier. Would there be any advantage in using the CX with a BM220.1 doing the low-mid duties?
MarjanM
B&C 4NDF34 dont go high enough.
That Volt driver is very good unit. I wonder whats the OEM price for it.
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
http://www.diyaudio.com/forums/pa-systems/297701-brainstorm-diy-compact-high-fidelity-pa-2.html#post4962425
concept-10
I was looking at these earlier. Would there be any advantage in using the CX with a BM220.1 doing the low-mid duties? [/QUOTI have mine running from 90hz and up, my tapped horns below, sound very nice
RosietheBand
Wow, this looks perfect for my needs - and so cheap! I might have to find some lower powered amps though, the Camcos are far too powerful for 4" drivers :-D I've just ordered 8 drivers, if it sounds good I'll probably build two pairs. |
MarjanM
Two columns of 4x4 inch drivers is very optimistic for 200 people.
We have made custom boxes for the Merriott hotel with some other manufacturer 4 inch driver. We made 16 boxes with 8 drivers each (note these are 1db louder, and double the power handling then the faital 4fe32) along with 8 15 inch bandpass subs for a 450 people ball room. So two 4 driver columns might be ok for 200 people presentations or conference, but forget having a party with two of those. Edited by MarjanM - 22 May 2017 at 5:57pm |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
I’m with cookie-dj on this, I have 2 pairs of tham-12s loaded with Beyma 12lx60v2 drivers, and again for their size they make a very nice noise and lots of it. If you need lots of sub 45ish hz they won’t be for you, if you want lots of 45-50hz and up bass in a very small and fairly efficient box they are just the ticket. Depending on the venue I use either 1 or 2 per side, Saturday before last I was using all 4 of them (2 per side) in a marquee powered by a PLX 3602, and they were making the windows and roof tiles rattle on the house 50mtrs away. The son of the people whose party it was plays in a band, he laughed when I carried them in set them up but stood speechless when I sound checked with them, and then asked “WTF are those little bins”. On previous years I have used 4 200ltr 18” BR cabs (similar to, but not the Fane design) to do the same event, the Thams did the gig with ease. They don’t drop as low as my 18s but they still make a very nice sound and for 99% of my work are more than adequate. Also they won’t couple like a proper horn, however using 4 does seem to make them drop slightly lower, this possibly more a “perceived” effect than actual. HPF them at 45hz and LPF them at 90-100hz and they will do you proud, any more than 100hz and they don’t sound as sweet. Edited by APW - 22 May 2017 at 7:58pm |
