Minirig |
Page <1234 26> |
Hemisphere
Posted: 29 April 2010 at 12:15pm |
Have you considered integrating a mixer into it?
For example: http://www.boysstuff.co.uk/product.asp?id=15603&random=&cid=&src=Search Weight is 200 grams, and if it retails for £20 I doubt it would add anything significant to the cost of production if you could work out an arrangement with the manufacturer (or just copy it :D) Would probably help to further define it as a literal "mini rig", rather than a high quality boombox. Edited by Hemisphere - 29 April 2010 at 12:17pm |
Jake_Fielder
Joined: 08 October 2007 Location: Stevenage/Nrwch Status: Offline Points: 4184 |
Posted: 29 April 2010 at 12:57pm |
thats more of a novelty product imo, you would need at least CDJs or decks to do anything really then you may aswell have a proper mixer. as you cant change the speed on an ipod, you may as well just plug both ipods in and adjust the volumes on the ipods to "mix"
Im abletronics, and so is my wife.
Meat
Joined: 05 June 2009 Location: France Status: Offline Points: 801 |
Posted: 29 April 2010 at 1:14pm |
Very nice looking Dave. I've been telling my housemate to hold off buying an ipod dock thingy until this comes out. I'll show him tonight.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 5169 |
Posted: 29 April 2010 at 2:18pm |
Perhaps consider using flush rotary dials for the gain, maybe on the rear? If you finish the final mould in that 'wood' style brown you had on an earlier prototype it'd look really, really nice. The dials and USB socket you have currently kind of make it look cheap and nasty, and that won't help sales much.
Similar to these dials:
darkmatter
Joined: 26 February 2005 Location: LDN Status: Offline Points: 2098 |
Posted: 29 April 2010 at 3:05pm |
Looking really good. Unless it's essential in terms of layout/space, I'd move the USB port to the rear and as Toasty says use detented (or recess the) volume controls. I'd keep the volume control for the main speaker & on/off switch on the front personally.
I know chunky big cables for a 3.5mm jack are pretty pointless, but my 3.5mm cable (http://www.chokemusic.co.uk/image/cache/atlantic_3mm-3mm-600x600.jpg) wouldn't fit in that I don't think as the volume control is too close. Is there a DC in for mains charging at the back? Hemisphere - that thing you posted looks like it could be good fun down the park - MP3 ports though!? hehe |
subbass
Joined: 30 March 2009 Location: bristol Status: Offline Points: 1683 |
Posted: 29 April 2010 at 3:09pm |
aye, recessing the knobs i reckon will make it far tougher, they are the only bits sticking out and will go first when dropped
davey t
Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1239 |
Posted: 29 April 2010 at 9:26pm |
yes i agree that it would be better to get rid of the sticking out volume controls.. but its hard find recessed ones when you're buying parts in singles from normal distributors and working with cots parts.
I just clocked the minirig (stereo) doing 108db at 1m in my lounge... pics to come
www.minirigs.com
Quality portable travel speakers Davey T: Electronics and audio engineering, PASCE Ltd |
rich_gale
Joined: 18 February 2008 Status: Offline Points: 2659 |
Posted: 30 April 2010 at 10:38am |
hey dave.
ordering 100-200 units from a bristol based company like Amalgam where they will do all mould making, casting and finishing will mean mould cost doesnt even come into it. id imagine they will just give you a unit cost. to keep costs down you should would aim to design the case so it has minimal sharp edges and detailing so as to limit the damage the mould incures per cast and then they are less likely to need to keep making new moulds. a spherical shape will also mean 'finishing' is kept to the minimum. colour/texture/material choice is also very important. im sure amalgam would suggest the best material to go for. personally im in love with an ABS style resin (cant remember the name) which casts extremely well and if dropped, has the same durability. due to the slight warp of curing resin it is worth factoring this into the design. maybe instead going for a flat face joint using a thin bit of rubber forming the seal. could you not have a basic screwdriver pot in the back for tweeking to their specific ipod/player and have the user just use the source volume control while in use? and have the on/off switch built into the input jack to keep it simple.
bassmish
Joined: 28 October 2007 Location: MAAAANCHESTER Status: Offline Points: 1232 |
Posted: 01 May 2010 at 6:17pm |
hi, just a suggestion, although I guess this just makes it all more complicated, but if I had one of these, I'd take it down the beach, and if I did that, I bet after 1 afternoon that USB port would be full of sand. so if there was any way that some kind of rubber plug could go over it to stop that happening, then it might be a good idea.
looks wicked. |
hond
Joined: 10 October 2009 Location: Louvain BEL Status: Offline Points: 510 |
Posted: 01 May 2010 at 6:52pm |
that's a good point :p |
Hemisphere
Posted: 02 May 2010 at 1:12pm |
+1 on the USB port thing.
I took a portable speaker to a festival, and although it didn't have a USB port, the mp3 player I was using it with did. The speaker was fine, but the USB on the player was unfixable. Edited by Hemisphere - 02 May 2010 at 1:14pm |
bassmish
Posted: 02 May 2010 at 7:45pm |
also, I was thinking, if you wanted to make one with a port, but didn't want it to fill up with sand or mud or whatever, just use a passive driver!! = same thing!
Page <1234 26> |
Tweet
