Minirig |
Page <12345 26> |
davey t
Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1239 |
Posted: 05 May 2010 at 12:03am |
On the port comments: yes I've thought of that and looked into it - there are no cots rubber bungs for usb b ports. Only the A type. Also, i'm sure it would get lost very quickly. The usb b ports are fairly big and robust and it'd power only, not data. I'm sure it would survive a bit of sand as long as you blew it out after. I'lk think about it though.
Passive driver is a nono. They don't exist in this size and the cost wouldn't be worthwhile. grill/foam is a better option. but yea, its going to be an outdoor product so need to think about all these things. Luckly the cone is pretty waterproof so thats a bonus. :)
www.minirigs.com
Quality portable travel speakers Davey T: Electronics and audio engineering, PASCE Ltd |
minaximal
Joined: 26 September 2004 Location: United Kingdom Status: Offline Points: 1499 |
Posted: 05 May 2010 at 12:49am |
looks good,
how about some of these for the sand: ![]() ![]() |
'My only law is the river breeze, That takes me to the open seas, If I could choose the life I please, Then I would be a boatman'
http://www.metaacoustics.com |
davey t
Posted: 05 May 2010 at 11:54am |
Good suggestion but too pricey
www.minirigs.com
davey t
Posted: 05 May 2010 at 9:48pm |
something like this should do the trick :
www.minirigs.com
Hemisphere
Posted: 11 May 2010 at 12:05am |
Just spotted the minirig in a banner for O2 ;)
![]() Okay maybe not exactly.. but an uncanny resemblance I'd say :D even seems to be the same driver! |
neilpoints
Joined: 03 March 2010 Location: Cornwall Status: Offline Points: 722 |
Posted: 11 May 2010 at 1:58am |
Hi. That's good work but I think it's got to sound better if you used a 2 or 3 or 4 way system. One speaker may be able to reproduce all frequencies, but it can't reproduce them all at the same time. The wider the range of any speaker and the more power, the greater the intermodulation distortion. Even a piezo tweeter would help, and would be very easy to add. I hope this helps.
double-ended-disco
davey t
Posted: 12 May 2010 at 8:31pm |
dammit you've found the source of my design.. There's a counter arguement which a lot of audiophiles and pro audio companys back to say that if you can get full range sound from a single driver then it is much better as you don't have the crossover phasing and distortion from using two or more sound sources.
www.minirigs.com
rich_gale
Joined: 18 February 2008 Status: Offline Points: 2659 |
Posted: 13 May 2010 at 8:51am |
a well designed full range transducer should infact have less timing issues than a 2 way system trying to achieve the same frequency band. how many good quality hi-fi speakers actually have physical time alignment? or delay systems? usually a dome tweeters vc is 50mm closer to the listener than the vc of the woofer on 2 way systems. also, i am of the belief that a well designed fullranger will suffer less intermodulation distortion than a pair of drivers over the same frequency band. im guessing this little unit has a highpass at 100hz? i cant see it making much of a racket below this? i will also say that in this area, no one expects response up to 20k anyway. picnic goers wont mind if that little driver starts to roll off at 15khz and a bit of electronic eq built into the board will counteract this. adding a tweeter adds size, cost, and undue hassle imo
rich_gale
Posted: 13 May 2010 at 8:54am |
ps, the timing issues will still be there (and as noticeable-which isn't very noticeable anyway) on a 2 way system because the critical band of 250hz-5khz will be being reproduced by a single diaphragm anyway.
Edd Jordan
Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 782 |
Posted: 27 May 2010 at 6:36pm |
i want to see more on this as it develops. i think its a great little speaker ps me want one.
davey t
Posted: 28 May 2010 at 8:18pm |
Thanks Edd! Yea, I've just today gone part time at work so I will be able to put some real hours into the business now. I'l keep you posted.
www.minirigs.com
davey t
Posted: 06 August 2010 at 9:46pm |
Hello to those interested. I've been working hard on this and keep hitting difficulties but i'm getting there. This is the current CAD model, not finished of course but will give you an idea:
![]() Its hopefully going to be quite elegant, cheap and simple to make as i'm aiming for the front and back halfs to be identical to half my tooling cost. Vacuum forming worked out very expensive, so i'm going to try to make my own silicone moulds from SLA and pour my own PU castings for the first 20-100. One of many design difficulties is the ports. Trying to control port noise and velocity at max volume whilest keeping the design complexity and costs to a minimum. Help and ideas very welcome!
Edited by davey t - 06 August 2010 at 9:51pm |
www.minirigs.com
Page <12345 26> |
Tweet
