Minirig |
Post Reply | Page <1 5859606162 79> |
Kerrse
Registered User Joined: 21 June 2012 Location: Newbury Status: Offline Points: 21 |
As i posted on FB i really want a set of BT ones but i have the full 2.1 set up already, plus would still need to wire the sub so may wait until you have the full set up on BT then sell my old ones or just have 4 Minirigs & 2 subs lol |
AlfieDring
Young Croc Joined: 04 September 2006 Location: Bath, UK Status: Offline Points: 842 |
Glad i got mine already then Is that for manufacturing simplicity / economies of scale reasons? And are intending to carry on with support for the ole ones? |
earthwormjim
Registered User Joined: 02 July 2013 Status: Offline Points: 27 |
broken my mini rig charger abroad and need to order a replacement barrell charger, what is the correct voltage etc to go for ?
66DeCo99
Registered User Joined: 23 November 2012 Location: Twaddle Town Status: Offline Points: 135 |
http://www.amazon.co.uk/MOGOI-Barrel-Power-Cable-Accessory/dp/B00NBH02FW/ref=sr_1_1?ie=UTF8&qid=1430465180&sr=8-1&keywords=usb+to+5.5+2.1mm+barrel+plug
One of those, standard voltage of USB 5V
The zone of danger
66DeCo99
Here's what I got for the summer for camping and the like. Tablet power backed up by a Anker E7, simply for the fact that I can't carry 1210's around. Should be a fun summer when I get my Minirig sub ordered.
The zone of danger
phildat
Young Croc Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
Can anyone put up a link to the best way of charging 3 subs and 4 mini rigs off one plug, so that the above can still be used while charging ? Had 5 minis and 2 subs at a stag do last week but couldn't charge em quick enough so eventually had to turn subs off for a few hours. Also want to design lightweight enclosure in which to place subs to amplify the sound. You know how they get louder when corner loaded in a room? Any one got any ideas? We mounted them all off a lighting t bar .sounded great but want something to put the subs in so the bass not as lost and is more pronounced if you get me? Gotta say the whole lot packs away into a very small case and with the t bar bagged up,it's a wicked mini rig!!!
Its just a ride.
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
Can I buy the bits to retrofit BT to the old model?
In reality what effect does the addition of BT have on sound quality and battery? Edited by AM55 - 13 May 2015 at 5:18am |
davey t
Young Croc Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
No. It's not economical to take apart the old Minirig. Plus it's a waste of perfectly good parts.
You'll struggle to notice any difference in sound quality between bluetooth and wired. The new Minirig has improved sound with more bass. Battery life is around the same in practical use. |
AM55
Are the minrigs serviceable?
slaz
Just curious (I don't have a minirig - although a mate does) - what about the battery ? Are replacements available ? Assuming yes - are they user fittable - given a degree of dexterity/competence ? |
AM55
That's what I'm getting at.
It must be a complete redesign for the new one if you can't just swap a PCB over or add a daughter board. (I must admit I haven't opened mine up so I'm not sure how they go together) |
lost eden
Young Croc Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
IIRC the subs can't charge fast enough to play continuously at higher volumes, no matter the charger - the sub itself won't pull enough current from the charger to match the consumption of the amp.
