  New Posts New Posts RSS Feed - mixing minis with full sized scoops
2bitNum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2bitNum Quote  Post ReplyReply Direct Link To This Post Topic: mixing minis with full sized scoops
    Posted: 11 October 2013 at 9:36am
Hi all,
Wanted to know if there is any wrong doing in adding 2 scoops(full size) to my 4 mini scoop set up? All together will run with the same speaker type, crossover freq and on the same amp.
Idea is to have 2 sets of minis stacked ontop of each other on their sides and to add one scoop standing up on each side.
Thank you in advance for your help and comments.
Autograff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2013 at 3:09pm
I would advise just trying to get more of the same design of minis
Liquid_Steel_Sessions
R8 Records
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2bitNum Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2013 at 8:36am
Thanks for the advise Autograff, what if i scale up the mini scoop design to a full size scoop?
was looking at this http://forum.speakerplans.com/the-mini-full-sized-debate_topic10073.html
Motion54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2013 at 9:21am
I believe the theory is, even full size scoops of different designs are not recommended to be stacked together due to phasing issues. The mismatched cabs have a potential of cancelling each other out.
Using identical cabs regardless of size allows the cabs to summ together without any possible dB loss due to phasing.
Mismatching boxes is like playing the lottery
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2bitNum Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2013 at 9:43am
Thank you Motion54, i dont play the lottery so i better stick to the same design
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2013 at 3:09pm
What Motion said, more boxes makes more issues.
R8 Records
