  New Posts New Posts RSS Feed - Modified 186 horn build pics - more added 10/06/09
 Post Reply Post Reply Page  123 6>
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Topic: Modified 186 horn build pics - more added 10/06/09
    Posted: 04 November 2008 at 4:42pm
Built these back in May/June - never got round to uploading pics and I still haven't fitted metal bar handles or painted them... Pics of the rig at the gig can be seen here:
http://www.speakerplans.com/forum/forum_posts.asp?TID=2179&PN=381
Edited by Wrighty - 10 June 2009 at 8:29pm
ALL YOUR BASS ARE BELONG TO US.
breakdabeat pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breakdabeat pete Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2008 at 5:02pm
nicely done!
the jig on the table saw is class
٩(̾●̮̮̃̾•̃̾)۶
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2008 at 5:13pm
Haha, glad you like the jig :) I've seen proper tenoning jigs before (to get angles >45 degrees) on the New Yankee Workshop, but I managed fine by clamping the workpiece to a lump of 4x2 and running that along the fence. Unfortunately the blade guard and riving knife have to be removed for it to be used so you need to watch your fingers...
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2008 at 8:05pm
very clean and tidy build.  lovely job
tommysb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2008 at 8:11pm
Looks great! Loaded with 18sound drivers? How do they sound? How were they modified?
Tom
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2008 at 8:25pm
i must get a load of gasket tape. lovely build.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2008 at 8:37pm
Thanks for the comments Smile
Yeah, Eighteensound 18LW1400. Sounded great for the live bands we had and CDs I played through it between acts.
EDIT: A mate of mine has just bought 4 Looneys, so we'll be doing an A-B between his and mine at some point...
Modifications:
- Made them 100mm narrower so I can fit 4 in my store.
- Chopped the bottom corner off at the back (to fit wheels on to).
- Different brace (reflects the last 2 sections of the horn and has cross braces too).
Gasket tape was from CPC and not expensive.
One day I'll get round to finishing them off and post the pics when I do! Need to make some jigs for routing out the sides for the metal bar handles before I can get them painted up though. Not rocket science but the weather isn't exactly brilliant for working outside at the moment and I'm trying not to make too much more mess in the garage!
Edited by Wrighty - 04 November 2008 at 8:39pm
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2008 at 12:53pm
Most definately!
**Heavy Weight-Line**
BEWProductions View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEWProductions Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 5:57pm
I noticed the insulation you loaded in the driver chamber. I have four of the 186s that I had made. They sound good but I feel they could sound better. Is it a common thing to load the chamber with wadding on horns? I dont think ive ever seen this on them before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 6:26pm
Well, I was finishing them in a rush and couldn't find a quick answer as to whether they should have wadding in or not, so I went with. Later, I read some discussions about Looney Bins (which are a very similar design to the 186/1850) which said they don't have wadding in.
I'm planning to take the wadding out of a pair and A/B them, but I suspect I'll end up taking it out, as that's how they're supposed to be.
What drivers have you loaded yours with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEWProductions Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 7:10pm
Mine are loaded with RCF L18 P300s. Decent drivers and Ive started building some 2X18" reflex bins that so I can pull them from the horns and put them in the reflex cabs.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 8:15pm
Originally posted by Wrighty Wrighty wrote:
Modifications:
You do know, you have now reduced the chamber size and Horn mouth.Shocked
Was hoping "modified" meant slightly deeper, slightly taller.
Edited by levyte357 - 05 January 2009 at 8:16pm
This page was generated in 1.281 seconds.
