MOSFET Amplifier? |
Post Reply | Page <12 |
ape3435
Young Croc Joined: 23 August 2009 Status: Offline Points: 552 |
Have to agree with you Earplugs, I once used a Macrotech 5000i on a float and the genie kept shutting down, I used the same genie another time with el cheapo Samson amp and there was absolutely no problem.
ape3435
I think the point is that despite the type of genie, the torroidals seem to continue working but the smps won't.
Earplug
"A massive part of these experiences is the genkit itself. Are we talking
a little Honda fluctuating all over the place or a small portacabin
sized professional beast? Results will change again."
Yes - obviously depends on the generator - but I`ve had a couple big units (30/50kVA) giving problems as well. A lot of these gennies get thrashed on building sites and then sent straight out to festivals with no proper maintainance or checks done on them. There`s one big hire company here that`s notorious for this, but people still use them as there`s not a lot of choice. The only solution is to always hire an extra in case one goes down. Not good. Edited by Earplug - 05 May 2016 at 5:47pm |
csg
Off course it depends on both the amps and generator but in the 20 years ive been using Labs and the last few using Powersoft i have never had an issue with SMPS amps of generators.
The last racks of linear psu amps we had were crest P8001/9001's which were fairly good on gensets and electrovoice P3000/2000 which were much more sensitive to voltage and particularly frequency fluctuations. Buss fuses seemed to be prone to going when the supply was not ideal. One site we regularly supply has a house supply fed from large gensets ( around 1/2 MW) which suffers from low line voltage with 170V or so being quite common when the site is very busy and demand high on their rather under spec'd distribution infrastructure. The Labs we run on that site simply get on with it with no drop in power, or any other issues. I cant see a linear amp doing that. Off course my own views are formed by my own experience, but sweeping statements saying that you need to use linear psu amps on gensets are not really true.. |
jbl_man
Let's hook a Behringer iNuke up to a little 1.5kva Honda with a lawnmower engine and see how long it lasts. I think under those circumstances i would rather have an old PPX or HH. But it is an interesting subject this. Amazing those Lab amps will run perfectly at just 170v Chris,wonder how low it has to drop before they stall? |
odc04r
Don't forget bridged into a piece of copper piping.
Earplug
"...but in the 20 years ive been using Labs and the last few using Powersoft i have never had an issue with SMPS amps of generators."
"Off course my own views are formed by my own experience, but sweeping statements saying that you need to use linear psu amps on gensets are not really true.." Likewise. We all learn from our experiences - especially the bad type. Maybe Labs and the newer Powersofts are more tolerant/better made, who knows, but it does seem that if you have a choice between a 'budget' linear and a 'budget' SMPS, linear is the way to go... |
csg
ill agree with you there... Amazing those Lab amps will run perfectly at just 170v Chris,wonder how low it has to drop before they stall? Well Ian, the Labs will operate between 70 and 265V, and our newer generation Powersoft amps operate anywhere between 85-440V. Neutral-live, phase-phase, they don't really care.
ape3435
I'm not sure if a Crown Macrotech 5000i is a budget amplifier but the Samson definitely is and like I said earlier it kept the genie running but the macro would cause the genie to shut down (quite a few times too).
