  New Posts New Posts RSS Feed - MS 18
MS 18
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Topic: MS 18
    Posted: 19 January 2011 at 7:23am
Could someone let me know which design would work best with the Fane 18 SB? Got a few of these drivers hanging around and fancy a mini scoop.
Bit confused generally which plan works best with which type of driver.....?
www.stableaudio.co.uk
Speaker Building Services
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2011 at 7:37am
did you mean XB?
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2011 at 9:43am
It just is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2011 at 10:04am
I see
they seem to be coming out thick and fast
please tell me 6.8mm xmax is a typo error?
EDIT:  just looked at the specs (thanks builder) 1000 watt AES and a xmax of 8.25mm
I would ask around first and see if anyone has attempted to put one of these in a scoop, if you're going to be using that kinda power, the rear chamber will have to be pretty small, otherwise you will run into trouble with as little as 500 watts
so no point in having a hungry 1000 watt driver
Edited by mykey- - 19 January 2011 at 10:14am
Preacher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preacher Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2011 at 9:40pm
Anyone know if this is a candidate for a superscoop?
Stone Lion Sound System, The Garden City Rockers. It's all about the music & the vibe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2011 at 3:49am
should be fine in a super, has a smallish chamber, more control
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preacher Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2011 at 9:23pm
Thumbs Up Thanks Mykey.
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2011 at 2:21am
I see
Actually 'only' 800W AES..... but yes, xmax of 8.25.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2011 at 4:04am
yeah I saw the typo error
someone at fane should spend some time going through correcting and bringing up to date
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2011 at 2:24pm
PD are at it too - RMS, AES who knows!
So with regards to eticate your best off putting monsters in bigger chamber scoops and weaker drivers in smaller chamber - so what happens when you put a monster driver in a small chamber?
Looks like the inevitable journey into scoops has begun...
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2011 at 4:00pm
Haha, if you end up lost and confused just repeat JBL/Emminence three times and you'll wake up.LOL
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2011 at 7:29pm
SILLY SPLApprove
TRENDSETTER SOUND SYSTEM
