MT 12 |
Post Reply | Page 123 4> |
catalin
Registered User Joined: 02 April 2012 Location: London Status: Offline Points: 152 |
Posted: 17 January 2016 at 10:25am |
Hi everyone!
Just started building it,the horns is 70 mm longer then original ,hope to get a bit of low extension More pics to follow |
cravings
excellent work on the joins! they should be very solid. is it all 15mm ply too?
catalin
Yes,is 15 mm ply
Now i'm working on the enclosures,i wonder wich is the optimum volume of the back chamber?
Brutus
Registered User Joined: 27 November 2015 Location: Utrecht,Holland Status: Offline Points: 101 |
woow, looks f%#^5ing amazing! good job!
catalin
catalin
odc04r
Nice router work on those handles, well done
cravings
agreed.
but possibly slightly over engineered given that the boxes don't actually have to be airtight in these. but yeah... very good. |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
beautiful work man, did you use a biscuit joiner for the joint or is that done with the router too?
cheers Adam
This account is used by 2 people. |
catalin
Hi there
I used table saw with tilting blade I runed the blade twice,so the grove is 4 mm wide,then ai cut somme strips and glued together Very strong joint
catalin
catalin
