  New Posts New Posts RSS Feed - MT122 v MT121
MT122 v MT121
Dub Koala View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Koala Quote  Post ReplyReply Direct Link To This Post Topic: MT122 v MT121
    Posted: 07 March 2017 at 11:16pm
Hi all,
I am in the process of building a 4 scoop stack for playing heavyweight dub.  I have decided on the scoops and kick bins and now have to make a decision on the mid/tops.
My question is from all of you listening experience would you go for the MT 122 or th MT 121.
Cheers!
P.s cost or size isn't an issue - just want the best sound possible.
Edited by Dub Koala - 08 March 2017 at 8:38am
m0gsi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m0gsi Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2017 at 11:51pm
Go MT121s if you're running 4 scoops. Single 12" section is plenty loud enough with a decent driver
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Koala Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 5:24am
So you wouldn't want to go for extra loudness with the others?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 9:31am
how many a side / per stack are you thinking? and what high horns have you picked? the dispersion of the high horn will sort of dictate how many you can put a side.
and what are your kick bins you've chosen, out of curiosity?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Koala Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 8:09pm
I'm going to be having a 4scoop stack only so no 2nd stack at this point. I was thinking to have two MT's combined with two HD215 for my kicks and the 4 scoops. I haven't picked the horns yet, I'll make that decision once I choose a cab for the MT's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Koala Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 8:11pm
I've come across the MT130 aswell. Any thoughts or comparisons with the MT's mentioned above? Cheets
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 8:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote m0gsi Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 8:44pm
The MT121 is roughly a 60 degree coverage box although I don't think I've seen any plots for the coverage of the 12" horn, the Hf horn is your choice.
You'll probably want 3 boxes to give you the width of coverage for wider rooms.
