mt122s without kickbins? |
Post Reply | Page 12> |
keilamym
Registered User Joined: 20 November 2007 Location: California, USA Status: Offline Points: 441 |
Posted: 03 February 2013 at 4:51am |
just wondering if anyone was running the mt122 without kickbins... and if so, do you think you need them?
Edited by keilamym - 03 February 2013 at 4:52am |
bass*en*mass
depends on your bass section i would say..
using mt`s above scoops or 6th order bandpass cabs would require a dedicated kick bin to fill the gap, using them above reflex or bandpass horns or frontloaded horns that dont have a long hornpath (above 2m) would work well if the cab plays fine till 130-150 without sounding "hollow/honky".. |
keilamym
i understand... thanks
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
There is an easy fix to use the MT122 on scoops
haujobb
New Member Joined: 27 April 2006 Status: Offline Points: 9 |
Go on...
phildat
Young Croc Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
run scoops slightly higher. been there done it. all sounded great
Its just a ride.
haujobb
Dang, I was hoping for some magical solution to get the MT121 to play down to 90
Currently build a ported sub that is "supposed" to play to 160, love the idea of running a pair of MT121 per side, but that is going to depend if the sub can actually get high enough without going to shit. |
cravings
pair of mt121 per side is a fairly big rig.. don't know what ported sub you're building but you'd probably need 4 a side to keep up with the mts. and you'll want the mts up so the high is pretty much over peoples' heads..
haujobb
Currently using PRX as tops, just wrapping up the build on the first sub. Assuming it performs, 3 more will be on the way.
MTs won't be happening until the rest of the rig is sufficient to support them. |
mykey-
levyte357-
Obviously referring to Chinese/Indian firms who mass produce from free plans, not individuals. |
malina
Registered User Joined: 30 October 2008 Location: Croatia Status: Offline Points: 190 |
Could you PM the solution? If so then I would realy like to see/hear it. Obviously I am a Chinese/Indian copycat :) Cheers. |
Malina Audio
