MTH-30 (again!) |
Page 123> |
mikey bear
Joined: 29 October 2007 Status: Offline Points: 2377 |
Topic: MTH-30 (again!)Posted: 24 October 2010 at 12:07pm |
Finished the 1st of 4 cabs yesterday. Will knock up the other 3 this week. Very quick and easy build, i would have thought if a whole day was spent building then all 4 could be finished in good time. A good cabinet to try for anyone's first build, and a good introduction to building horns i think.
Also good value for money... 4 cabs from 3 sheets of 15mm and under £80 per driver. First impressions after testing in the garage were positive, cab sounds good and goes low enough for most types of music. Although with a -3db point of 52hz it doesn't quite do justice to some of the heavier digidub/dubstep records. I'll add more when i've tested all 4 in a small venue soon and worked out some PEQ settings. ![]() ![]() |
Saul
Posted: 24 October 2010 at 12:21pm |
i too heard one of these the other day and was pleasantly surprised. nice sounding bass, and quite accurate.
they don't drop very low, but i reckon if you piled them up in a stack of 8 they would! great little things for the size of them!!
mikey bear
Posted: 24 October 2010 at 12:26pm |
i'm expecting my stack of 4 to be quite pokey. i'm not sure however on the theory of coupling and tapped horns ie if they even couple at all. if anyone can shed some light on that one i'd be most grateful.
S DeXter
Joined: 12 May 2008 Location: Moon Status: Offline Points: 1260 |
Posted: 24 October 2010 at 12:32pm |
Nearly all cabs will couple due to the increase in radiation surface.
Enjoy your self...... It's later than you think.......
GekoMusic94
Joined: 03 February 2010 Location: Italy Status: Offline Points: 314 |
Posted: 24 October 2010 at 12:52pm |
Looks good
! What's the tops?
My life is BASS...
mikey bear
Posted: 24 October 2010 at 12:57pm |
Turbosound TQ310
Tony Wilkes
Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 3367 |
Posted: 24 October 2010 at 1:29pm |
They couple as in mutual radiation but I do not believe that you get any additional extension at low frequencies, at least not to the degree of RLH.
Tony |
www.forteaudio.eu - BMS - db-Mark Processors
GekoMusic94
Posted: 24 October 2010 at 1:30pm |
1 sub is enough for 1 top?
My life is BASS...
subbass
Joined: 30 March 2009 Location: bristol Status: Offline Points: 1683 |
Posted: 24 October 2010 at 6:06pm |
1 MTH-30 to two 8" top for live work 2 MTH-30 to one 8" top for heavier bass my findings
![]() Edited by subbass - 24 October 2010 at 6:22pm |
rich_gale
Joined: 18 February 2008 Status: Offline Points: 2662 |
Posted: 24 October 2010 at 6:15pm |
how high will this play before sounding grunty and harsh? lovely looking little cab
GekoMusic94
Posted: 24 October 2010 at 6:21pm |
I think my MTH-30 and my 2 8" tops ( http://www.fbt.it/ENG/PAE/PRODOTTI/SPEAKERS/JOLLY/Jolly-8r-a/ ) are perfect for dance music because the tops SPL is only 114 db...
What do you think? |
My life is BASS...
subbass
~150hz in my experience. above / around there it starts to sound a bit off
Edited by subbass - 24 October 2010 at 6:23pm |
Page 123> |
Tweet
