  New Posts New Posts RSS Feed - MTL-46 build!
MTL-46 build!
Darkstar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 8:49pm
Belli, bravo Clap
I think I will make a couple of these as I've got two spare RCF L18S800 and they kind of match the thiele/small parameters of the G401s.
Can you please tell me what you're going to use to apply the warnex paint? I have some but I haven't used it yet as I'm struggling to find anyone with a paint-gun with pressurized material container.
Edited by Darkstar - 27 May 2015 at 8:49pm
Bass =/= Enough
GekoMusic94 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2015 at 5:32pm
Grazie Big smile
I use a roller. I apply a thin coat and then when is dryed i roll a thick coat to obtain the textured effect. With a paint gun it will be easier and the grain of the texture will be much grater..however i'm satisfied enough rolling it.
https://soundcloud.com/dj-uber
Post Options Post Options   Thanks (0) Thanks(0)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2015 at 9:41am
Here are some finisced pics:
The grill is missing from the pics Smile
I've tested this week end on a private party with about 100 peps and it sound just awesome! Very clean and deep and the spl is good, it makes your chest thump! Keep in mind that now i'm using it with my two fbt jolly 8 tops so i didn't run it at full tilt. Overall i think it's the perfect cab for me as it fits in my renault modus and i can move it around by myself and it sounds awesome.
Giacomo Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2015 at 10:09am
They look fantastic. Curious how you're placing them horizontally though, are you using them side by side?
I will probably build two in this or next month and load them with some RCF L18S800's, hopefully they'll sound as good. Simmed them and did not look bad at all, except some over excursion at 50Hz-ish.
All that you have to do now is to get a replacement for the FBTs so you can run these at their full potential.
Bass =/= Enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2015 at 11:06am
Thanks! Maybe you can build also a ESW1018 copy for yours L18S800, as i think is it's original woofer.
I've placed the feets horizontally just because i like the look more Wink also the idea for the future is to build 3 more and two 2x12" and with two subs stacked horizontally per side i will have enough height for the mid tops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Posted: 31 December 2016 at 6:04pm
Little demo at the end of the video :) nothing fancy
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 31 December 2016 at 6:18pm
I have that crossover and can't get it to work for me... I never understand the menu system how close do you live? I'm SENDING London and would love to get it going properly.
