Multiple power generators |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Posted: 14 September 2014 at 12:43pm |
Will i get burned if i use one genny for sub amp and another one for tops/kicks?
Googled a bit didnt read anything explicitly saying its a no no. I can live with the buzz if it happens,anything else i should be aware of? |
ceharden
At a minimum you're going to need a good low impedance earth bond between the two. Last thing you want is signal cables between your equipment providing the common ground.
Edited by ceharden - 14 September 2014 at 12:46pm |
jacethebase
Not advisable.
www.stage2sound.com |
EHaudio
Registered User Joined: 11 April 2014 Location: London Status: Offline Points: 51 |
Out of curiosity can't you request for a decent genie to run it all from?
How big are the genies your going to use? |
Did you plug it in?
