My 18" horn, Invader Bin |
Post Reply | Page <1 1819202122 39> |
kula
Registered User Joined: 09 June 2005 Location: United Kingdom Status: Offline Points: 203 |
thank you that would be appreciated.
Luke
Registered User Joined: 06 May 2010 Location: Norfolk Status: Offline Points: 443 |
Finally!
JDCutta
Registered User Joined: 24 June 2010 Location: North Lincs Status: Offline Points: 555 |
Looking tasty indeed!
Luke
Thanks(1)
We need more invaders in the world..eye wobbling bass.
nineleaves
Young Croc Joined: 31 August 2007 Status: Offline Points: 1327 |
Grins.. much approval, nice job :)
Luke
Nice job to you! Very impressive cab! Thank you for sharing the plans!
nineleaves
:) ...Ill put up the designs for the single lab 12 one next.
Still got 8 of them to sell here due to alot of time wastering going on. |
Luke
How do the single lab's compare with the original lab design?
Those invaders were moving some serious air with the amount of matrix behind them
nineleaves
Design on the single lab 12 has been improved imo in a number of respects, theres a much larger air coupling area than the original labs, allowing use of less drivers/boxes to get a beefy result and 'ideal' coupling. They include a force air cooled heatplate system that transfers heat directly from the drivers pole piece to the 'outside' air, which amoungst other things helps prevent the driver from cooking under prolonged use. also each cab is a far more manageable 65kg ..instead of the lab x2's 100-120kg ! 8 in a linear line are shockingly directional in the horizontal plane, 8 stacked in a manner like the invaders above provides an efficient, yet wider spread dispersal. so overall quite flexable things :)
Luke
How do you manage such efficient heatsinking? I have considered doing similar to the psycho's and just using a finned alu plate with a huge surface area not actually attached to the drivers? having the hatches in open air seems much more sensible, Most labs i see have heatsinks for the hatches but are stacked touching one another anyway?! What's the outside dimensions of your version?
nineleaves
The solution on paper to the problem isnt wholly ideal, but in reality it actually works really well :)
consists of a hollowed out aluminum insert that goes into the pole vent on the lab 12 driver, whilst still allowing it to breathe in the rear air volume, this is then thermally coupled to an aluminum panel in the airpath of the horn as it folds round the driver, works astonishingly well. Spanked the cabs flat out all day and night one weekend and then took the access hatch off & measured temp ..barely above room temp ..something like 23-25c if i recall correctly ? |
Luke
That's pretty impressive! is there any room around the aluminium insert to allow it to still cool in the air in the rear chamber? or does that not matter as much as good contact with the insert for increased conductivity to the heatsink panel?
