  New Posts New Posts RSS Feed: My 18" horn, Invader Bin - (Now with plans).
  FAQ FAQ  Forum Search   Chat Chat  Calendar   Register Register  Login Login
 Post Reply Post Reply Page  <1 8910
bitzo View Drop Down
Online Status: Offline
Post Options Post Options   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Topic: My 18" horn, Invader Bin - (Now with plans).
    Posted: 31 July 2010 at 5:45pm
without the panel c you have a lot of volume on vrc so would be a worth porting this cab?
t.geessounds View Drop Down
Post Options Post Options   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2010 at 10:41pm
Originally posted by Calculus
so basically F and C,
 h is a guess also...
b i'm not sure of either.
what i needs to do is draw the plan on the side of the cab board and F,C,H & B will come Wink
Calculus View Drop Down
Post Options Post Options   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2010 at 11:38pm
Thanks for being so useful!!!!!!!!!!!ClapClap
that doesn't help getting the wood cut first...
nineleaves View Drop Down
Post Options Post Options   Quote nineleaves Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2010 at 4:16am
Ah well.. Like moths to the flame, they're gonna get burned.
heinrich View Drop Down
Post Options Post Options   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2010 at 9:07am
clearer this time
Edited by heinrich - 04 August 2010 at 9:32am
.....power is nothing without control....
Post Options Post Options   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 4:14am
Originally posted by nineleaves
This should do it:
http://sites.google.com/site/nineleaves/home/f/18B600_D3.PDF
cheers thats clearer... I've just got the wood for 6 of these satrted marking them out aswell before you put up these amended plans...
I'm still not quite sure whats going on with the diagonal pieces in front of the driver but, I'm making good progress on the rest.. only thing is my six will be 636 wide (600) internals, Think i over estimated on the ply though at 12 sheets i think i could've done it with less sheets, we will see.
Got excited about plywood as i found a temporary workshop to use two doors up from the wood yard. will get photos of progress...
Post Options Post Options   Quote nineleaves Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 4:25am
if you mean the ones marked 508 & 590 ..the first one is a gasket to allow for driver excursion & the second is the section with a half moon semicircle cut out of it, setting the way in which the drivers air load joins the rest of the horn.
Post Options Post Options   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2010 at 12:48am
I Wasn't meaning those two panels but that has confused me further. I meant the two either side above the driver the triangled shape ones...
Post Options Post Options   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2010 at 3:47am
i meant the bits either side of the half moon...
Bulletin Board Software by Web Wiz Forums® version 9.69
Copyright ©2001-2010 Web Wiz
