  New Posts New Posts RSS Feed - My BSS 966 repair photos
Stray-Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Topic: My BSS 966 repair photos
    Posted: 18 February 2012 at 5:06pm
This is my first attempt at this kind of work so go easy on me Embarrassed
Thought that this may be useful to anyone unsure about attempting to repair one of these!
Thanks to Shagnasty for parts and advice Thumbs Up
You'll probably find more faulty faders!
Old solder pumped out, not pictured
This bit has to slot in first!
All working fine. 2 units down 1 to go! Smile
simonp1100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2012 at 5:27pm
Nice job. i had 6 to repair in one go (came out of a PA company hire stock). Took ages to do one & a real pain in the neck to re-fit the metal fixings to hold the PCB to the front panel.
GOOD LUCK. CryCry
balistic_sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote balistic_sounds Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2012 at 5:48pm
i have a clip light constantly on on channel 1. any idea why this is. first thoughts..??
Don't underestimate no sound!
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2012 at 7:06pm
Check to make sure it's nothing silly like a blob of solder or splash when you were fitting the sliders etc. If the unit works perfectly, but just the clip light stays on, follow the clip light back to which chip/transistor drives it & change it would be my first port of call. Regards
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2012 at 1:22am
You used a screwdriver...bugger...that is why me hitting them with hammers doesnt work. It's obvious now!
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 12:32pm
OK so I've fixed the last unit now. everything went fine...
but when I came to test it I found that the main volume pot would crackle and make a horrible racket when its turn down to its lowest setting. The 'LF Contour' does the same. all the sliders seem to work OK apart from 16khz wich seems to boost like crazy when its up full. and 400 hz in its highest position will also boost a much higher frequency.
Its usable as it is, as I never run the volume that low and never boost a frequency to +16 but it would be nice to have it working 100%
Anyone have any ideas about this? I can't see any problems with the work that I've done. no blobs of solder anywhere etc...
Thanks
Forum Software by Web Wiz Forums® version 10.11
