  New Posts New Posts RSS Feed - My little sound systems
Sm1thson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sm1thson Quote  Post ReplyReply Direct Link To This Post Topic: My little sound systems
    Posted: 28 February 2014 at 10:48pm
So a couple of years back I decided it would be a good idea to build a portable sound system, the main motivation was something to use when slacklining with friends (google it if you've not come across it). My budget was basically <£5 (spent too much on other hobbies lol), so I bought a cheap battery holder off ebay, I already had a stack of 18650's for high power torches(flashlights), I had an old rubbish car amp, and there was a couple of rubbish speakers in the garage from the previous owner, oh and a switch of a mains electric lamp.
I put it all together and this was the result:
MK1:
It did the job, and I soon realised that I should make a better job of it and put some better speakers on it, I had a single old Bang and Olufsen speaker that my late granddad bought from a charity shop for £1, over the years it had been used as a centre speaker, a computer speaker, and was then just sat in the garage. so I saved it from rotting in there and put this together (together with an old hifi bookshelf speaker I had) .
MK2:
This proved a bit heavy, there were times I could do with something a bit lighter.
Years back I had driven this speaker of an amplifier I made based around the LM380 and although pretty low power kicked out a reasonable amount, I figured this in the smaller speaker would be handy then bring out its big brother when needed.
I couldnt find the old circuit I made, in the meantime whilst looking I ordered a bluetooth module, theres not much to the amplifier so I made another one. note the blue thing on the battery pack is a self resetting circuit breaker.
MK3.0:
Now before this was even hooked up I had done some googling and realised how cheap efficient D-class amps can be had so an order was placed for a <£5 TA2024 board form china (no doubt the more expensive ones will be better, but it works and thats all I need).
Now it has arrived and its time to put the electronics into the housing:
MK3.1 (pre-assembly):
Ive mixed the left and right together via 2 1K resistors.
Ive changed the feedback resistor so I can get volume out of the crappy ipod (phone and bluetooth were fine)
I'll be putting the bluetooth module inside too, Ive used a DC to DC isolated converter (else it buzzed big time), I only and a 5Vout one to hand to bodged on a 3v3 linear regulator, not the neatest or most efficient way of doing it but it doesnt pull much current anyway so Im not worried about it. (and the bluetooth can be switched off and driven by 3.5mm jack).
I thought I'd post up, firstly to motivate me to finish, and secondly to help inspire others that 12V soundsystems can be built simple and cheap so if anyone want to build one they should. I have a friend 100 miles away who isnt as technical as me, but hes building one (when the bits arrive from china). Basically all you need are some batteries, fuse (car one will do) amplifier PCB, speakers (the more efficient the better, but if you have some laying around why not just go for it!).
Edited by Sm1thson - 28 February 2014 at 11:15pm
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2014 at 12:35am
Thats the way!Thumbs Up
"what!?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sm1thson Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2014 at 9:43pm
Right then Ive pulled my finger out and finished it off.
heres a pic with the handle:
Heres the general layout of the back:
Ive kept the batteries external and on a plug for ease of charging and swapping to another supply eg SLA.
it has the on off switch, and one for the bluetooth module, it has a 3.5mm input and a pushbutton that lights up a built in voltmeter.
Heres the voltmeter in action:
and heres a vid of the whole thing in action (recorded on phone so the recording sounds rubbish, promise it sounds good in real life )
http://s26.photobucket.com/user/sm1thsonebay/media/2014-04-06094000.mp4. - http://s26.photobucket.com/user/sm1thsonebay/media/2014-04-06094000.mp4.html
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2014 at 11:43pm
Thumbs Up
functionally minimalist, love it!
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2014 at 1:28am
Excellent work man hope you have a lot of fun with it :) Love your little circuit breaker too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sm1thson Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2014 at 8:57pm
Thanks, I first used those circuit breakers when I was mid teens and got into CB radio, Maplin sells then and they are most handy.
I am thinking now I want more volume, I think I might change out the cones, 4ohm and more sensitive would be a sensible step. the current speaker is 8ohm woofer and 87db@1w@1m
Edited by Sm1thson - 16 April 2014 at 9:00pm
