  New Posts New Posts RSS Feed - Need Help Simulating dual reflex for Lowrider 18
DiscernAudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscernAudio Quote  Post ReplyReply Direct Link To This Post Topic: Need Help Simulating dual reflex for Lowrider 18
    Posted: 08 November 2011 at 6:56pm
I am building two dual 18 reflex cabs for Peavey's Lowrider 18.
Each cab will be powered with a QSC PLX3402 (bridged 4 ohm)
I am using bass box pro for cab design so far.
Music that will be played is primarily Drum and bass, dubstep, roots, and hip hop
I am looking for a nice flat response, but cant seem to find it without huge volume.
I think I would like to aim for Vb=400 L or below.
Could someone maybe shed some light?
Speaker specs are...
Znom (ohms) 8
Revc (ohms) 6.21
Sd (Square Meters) 0.134
BL (T/M) 22.17
Fo (Hz) 28.9
Vas (liters) 288.0
Cms (uM/N) 113.3
Mms (gm) 198.20
Qms 9.07
Qes 0.451
Qts 0.429
Xmax (mm) 9.6
Le (mH) 0.87
SPL (1 W 1m) 96.0
no (%) 2.65
Vd (cubic inches/milliliters) 145 / 2375
Pmax (Watts pgm.) 1600
Disp (inches/milliliters) 235 / 3852
Also, some of these specs copied from the spec sheet dont add up? Sd, Xmax, Vd? Qes,Qms, Qts, BL?
Also, peavey recommends 6 cuft/driver tuned at 34 hz, but if you input their recommened port size and length, it doesnt add up either?
aperrado View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aperrado Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2011 at 4:10am
Hi , no to  much answers, but ifi  you decide to make this project keep updateds on
good luck.
Im hard to learn but still asking
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2011 at 11:26am
Why dont you just copy Peavey QW218 box?
Head of engineering
Bold Audio Inc
www.boldaudioinc.com
http://www.facebook.com/pages/Bold-Audio-Inc/323691856723
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2011 at 12:13am
www.peavey.com/media/pdf/manuals/80304779.pdf
there are 3 designs peavey gives you- small, med, & large cabs. Bigger the cab lower the cutoff.
We learn something every day, and lots of times it’s that what we learned the day before was wrong.
rffrecords View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rffrecords Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2012 at 10:44pm
The only way to keep your boxes under 400Lt is to use the isobaric configuration (driver properties->configuration tab in BassBox). You lose sensitivity (SPL) but required volume drops to one querter of the standard twin or push-pull configurations!
Those peavey 18s didn't impress me at all but since it appears you got 4 of them I think you better put them to some good use. I managed to get an SPL of 124dB with 1100watts (your amps can't deliver more) from 31Hz up (-3dB), flat from 41-220Hz using a vented box of 275Lt and 4 vents 6 inch diameter and 380mm long. That gives an at least 6dB peak caused by the vents at 295hz, but if you cross the subs 180 or 150hz down, it doesn't matter.
If you are still following your thread and post a reply, I could find the time to upload photos and some BassBox files. Also do some research on the isobaric configuration (as this if the only way to go if you want a flat response with these drivers for less than maybe 900Lt!) and on how to build an isobaric chamber (it isn't that difficult).
Steve_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve_B Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2012 at 11:13pm
based on the figure you posted above winisd comes up with the following max spl graphs.
Form these results there seems little point in using a larger cabinet.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2012 at 11:27pm
Have you bought the amps and drivers already ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rffrecords Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2012 at 11:47pm
On my previoys post 275 Lt is a mistake, I meant 330Lt. Also I made use of the high pass feature of the QSC amps modelled as high pass at 30 Hz with a Q of .65 (just my guess it must be somewhere between 0.6-0.67 i guess). High pass is essential for PA. Moreover PA cable runs will add some resistance diving Qts closer to 0.5. All in all the driver is barely good for vented boxes. Bad PA woofer!
Jsadler is asking for "a nice flat response"
That's the best that I managed to get with bassbox. I haven't winISD installed on this computer and would like to what winISD gives because as jsadler said the driver's T/S are tricky to say the least.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rffrecords Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2012 at 11:54pm
Sorry that is the link to my frequency response:
http://www.2shared.com/photo/NmI6PVg6/123.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2012 at 11:57pm
Exactly why I asked if he had bought them already. Embarrassed
Also, buying an amp specifically for 4 ohm bridging on sub, with sub heavy material, would point me away from PLX3402.Embarrassed
Edited by levyte357 - 08 January 2012 at 11:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscernAudio Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 6:39am
I am no expert in this field but what's wrong with this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 6:04pm
Nothing. The simulation delivers a good response and, offers no power compression from a frequency versus wattage perspective.
I believe those who are complaining about Peavey are refering to the old Black Widow. The Low Rider is a completely different driver.
Best Regards,
Edited by Elliot Thompson - 26 March 2012 at 6:06pm
speakerplans@redhotmail.net
