Need help to set a brick wall limiter |
jasonn
Registered User Joined: 21 March 2011 Location: London Status: Offline Points: 152 |
Posted: 23 April 2014 at 8:14pm |
Hi, I just got a Composer Pro MDX2200 for the soul purpose of putting a brick wall limiter on my system to prevent DJ's ragging the sh*t out of it.
I've been told this requires something along the lines of setting the attack and the ratio correctly in order to use the threshold as a peak limiter, is this correct? Could someone please tell me the settings I need to set a brick wall limiter, it would be greatly appreciated. Thanks
Grubbah
Old Croc Joined: 14 July 2011 Location: Portsmouth Status: Offline Points: 2004 |
Ratio of infinity:1
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Not sure if the Berry has infinity to one. Next best case: use the highest ratio available, with the shortest attack and longest release. Do not use any 'Over-Easy' compression options that may be offered. At the least, I strive for an audible effect that will tell the offender to back off the gain, but some may disagree with this approach....
jasonn
Cheers but I've already tried setting the Ratio to infinity and the attack to 1 and the Threshold seems to have no effect when i increase volume on the input source (just playing a song out of iphone for ease). I know what I want to do is really basic but I'm kinda new to compressors. Might need it spelled out a bit more... here's a pic of the front panel (just 1 channel but I set this as a stereo master): |
doober
Young Croc Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
Looks like the comp is bypassed. Push the "in/out" switch on the right below the 1, this needs to be lit up. Also turn the gate threshold (far left) anti clockwise to "off" or you might find the quiet bits get a bit too quiet.
Blahblahblah
jasonn
ok thanks a lot guys, getting some results now :) but when the compression/limiter kicks in it seems to compress the volume noticeably more during bassier parts of the song, i.e. with kick drums... sound kinda like side chaining.. is this normal? would if have anything to do with the 'SC MON' being on (red led button near the compressor threshold)?
also, does it matter what the gate ratio is set to?
BlueDragon
Registered User Joined: 02 March 2010 Status: Offline Points: 360 |
Turn the SC Mon off, it's been a while but I don't think it does anything if there's nothing plugged into the side chain sockets, turn it off just in case.
From the picture you've posted it looks like your problem is with the release setting. Attack wants to be at a low setting, as it is in that photo, but the release needs to be high. Set it to max then play with it a little till you get closer to what you're looking for. I can't tell from that photo whether the auto switch is on, make sure it's off
LjudLahger
Young Croc Joined: 31 July 2008 Location: Sweden Status: Offline Points: 838 |
Alot of this is explaind on youtube. Search for behringer compressor and such
shagnasty
your iphone wont trigger the comp!
set the threshold to -10 to compensate for you 10dB outgain
Grubbah
Thanks(1)
Turn the gate off (threshold as low as possible). You have no need for that.. Bass and drums entering the mix are big dynamics, so will push your signal harder. You're not trying compress your track, so notch your output gain back down to 0db, run up your signal input until your amps / xover / system starts to reach its limits and set an appropriate threshold at this point on a ratio of between 10:1 and infinity:1 and bring up your release! Your release setting controls how long the compression holds once exceeding your threshold. Too fast and your limiter won't be effective enough. It will sound a rubbish when you ride hard against them. So you know when you have reached the systems limits to your specifications As a compressor they are usually intended to control dynamics. You use the output gain to compensate the gain reduction.. The idea being you squash the dynamics of a signal whilst maintaining the gain level. Not needed for your application. Edited by Grubbah - 24 April 2014 at 1:45am |
