Neutrik SCDR to insulate rear of powercon? |
TMH Music
Young Croc Joined: 07 April 2011 Location: London Status: Offline Points: 635 |
Posted: 28 April 2016 at 2:48am |
Got to love the insomnia!! So, would any of you folks insulate the rear of a powercon, only using Neutrik's own SCDR insulation boot? I'm putting a 1u rack strip in the back of all my flight cases, so I can have all connections, including power, neatly mounted at the back of the rack, but I've never seen, let alone used, one of these insulation boots, so was curious as to their viability for protecting persons (idiots) against a mains power shock; or are they intended for only XLR/SPEAKON use. Your thoughts please folks. Much you very thank.
Nothing is foolproof because fools are so ingenious
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
Heatshrink would be less likely to come off in transit... And probably cheaper
TMH Music
Blimey James!! That's got to be the quickest reply in history!!!!
Thanks for that idea!! This is the reason I love this forum so much. Cheers mate, you're a star!! |
James Tengo
I'm waiting for a gig to start, its 7pm here, soundcheck finished at 4pm, band are onstage at 9...
snowflake
are you using pre-punched rack strip or are you getting one made - if so where?
TMH Music
@Snowflake, using pre-punched. 1u 12 D type holes.
shagnasty
TBH
you need to leave the mains in a state it is in-accessible without tools. (the above is bolox, WRT to Pro gear in a few ways, ut in argument with a house sparks that has just padlocked off your mains is important... Adhesive lined heat shrink may just pass muster
