New 15" Kick Bin |
Post Reply | Page 12> |
immortal
Registered User Joined: 07 January 2013 Location: Sheffield Status: Offline Points: 460 |
Posted: 06 April 2015 at 5:34pm |
I have designed a Quasi-6th Order Series-Tuned BP
its designed for the kappa 15lf it is 155.5l compared the the hd15 which is 169.7l driver displacement isn't a problem at 500w it doesn't go over its xmax. it is 600 x 600 x 432
Simmed in 2pi |
Cemetery Sounds
immortal
I will try and get some built over the next few weeks :D It can go down to 70hz without any excursion problems and it groups of 4 are flat down to 80hz. I simmed these and they all looked good: pd1550 fane colossus 15xb pd154 I have a feeling i might need to make the port a little bit shorter though. This is the pd1550, black, against the kappa 15lf, grey This is 4 kappa 15lf loaded: |
Cemetery Sounds
all bass
How does it look in 4pi? Kickbins are hardly ever on the ground.
immortal
It gets a little peaky in 4pi The pd1550 is a little flatter
Cemetery Sounds
immortal
I have redesigned it, its a little larger.
60 x 60 x 50 - 180L |
Cemetery Sounds
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2460 |
Its nice to see someone designing something new for a change. well done!
Mikkel
Young Croc Joined: 17 May 2013 Location: Huddersfield Status: Offline Points: 549 |
Immortal - how do you sim these type of enclosures in hornresp? Im struggling to downscale davey t's booty bass to a 12 and your design is the same vein if ya know what i mean. Any tips would be grwat
immortal
I would sim it as a tapped horn with a throat chamber.
I don't think you would be able to get it any smaller to suit a 12" driver though, try simming 12" drivers in it. You could try inverting the driver, which would make the rear chamber bigger and the mouth volume smaller then moving the mouth to the edge which would do the opposite which would potentially balance out. This would make the horn mouth bigger. EDIT: as the horn ends against the edge of the box I would make it slightly longer in the sim to compensate.
Edited by immortal - 07 April 2015 at 11:18am |
Cemetery Sounds
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Cubo 15 sims well up to 160 Hz but mostly sounds right up to 110 Hz, all hybrids I've build exhibited the same sound vs simulation behaviour. As soon as the phase response starts to climb up again be wary of it's sound.
Some of my conclusions when it comes to building hybrids for kick: (very) large mouth, small chamber, driver with magnet inside the chamber. Assume it's going to have an one-octave-bandwidth, perhaps just a bit more. Regards Johan |
immortal
Did you build any prototypes with a chamber as small as 30L?
I will build it and see how it sounds that high, the small chamber might help. If not I could dampen the chamber and make the port a little shorter.
Cemetery Sounds
Mikkel
I see. Thanks for the help! its a struggle to find a suitable design for such an important freq range (100 - 300/400hz), especially one that would be phase coherant with cubo18.
Thanks again guys |
immortal
Have you looked at the Cubo kick?
They can play up quite high. What tops are you using that only go down to 300/400hz? |
Cemetery Sounds
