  New Posts New Posts RSS Feed - New 4 channel amp
New 4 channel amp
 Post Reply Post Reply Page  123 15>
midas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Topic: New 4 channel amp
    Posted: 08 January 2017 at 7:18pm
Anyone else noticed Blue Aran listing their own branded 4 channel amps???
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2017 at 8:58pm
Sheggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2017 at 9:26pm
2R Hmmm. We'll see.
S
TMH Music View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMH Music Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2017 at 11:46pm
Bloomin' heck!!! 10Kw for under £900?!! Pictures please!! If the specs stack up this could be a game changer.
Nothing is foolproof because fools are so ingenious
Hvedstrup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hvedstrup Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 8:29am
Why such a odd voltage gain? 40db?
freddymendez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddymendez Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 8:49am
PFC?
120-140 bpm, pianos and bass.
diesel, the fuel of professionals.
mendez/manchester
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 9:06am
No detailed specifications sheet, No internal / rear pictures?
I smell "China works" inside :-D
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 12:17pm
Originally posted by knet94 knet94 wrote:
http://www.bluearan.co.uk/index.php?id=JMSQ10&browsemode=manufacturer
Originally posted by <a href=http://www.bluearan.co.uk/index.php?id=JMSQ10&browsemode=manufacturer%20 target=_blank rel=nofollow>http://www.bluearan.co.uk/index.php?id=JMSQ10&browsemode=manufacturer http://www.bluearan.co.uk/index.php?id=JMSQ10&browsemode=manufacturer wrote:
JAM Systems Q10 :: 4 x 2500W
A high-performance range of professional use switch-mode power amplifiers, delivering outstanding premium power from a compact package. Its elegant 1U-footprint reduces rack space and cost, and weighing in at a shade over 10kg, set-up and breakdown of your stage is quicker and easier. Thoughtfully-designed recessed stepped attenuators make for easy and precise matching of gain structures, and a completely modular channel architecture means that each of the four channels has its own dedicated power supply for ultimate stability, with zero crosstalk or interference between channels. Employing a classic pulse-width modulation design, high switch-mode frequency and precise controlling of deadtime makes for exceptionally low distortion, surpassing the quality of traditional transformer-based amplifier designs. The high efficiency power supply is kind to the environment and ensures weight is kept to a minimum, with a circuit tailored for reliability that helps make sure your amplifier will continue to provide you with driving power time after time.
Specifications:
  • Number of channels: 4
  • Output Power (all channels driven, THD = 1%) 8 ohms: 4 x 1100W
  • Output Power (all channels driven, THD = 1%) 4 ohms: 4 x 2200W
  • Output Power (all channels driven, THD = 1%) 2 ohms: 4 x 2500W
  • Frequency response (@8 ohms): 20Hz - 20kHz, +/-0.3dB
Those specs would make this effectively, more powerful than Inf8MK2.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 12:53pm
the biamp one looks pretty useful too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 1:30pm
Now, Andy, if you can just add a Q5 to the list. I will have one Q5 and 2 x Q10, thank you...lol.
Not a bad little system then, 4 x TMS3's and 8 twin reflex 18's.
1 x Q5
2 x Q10
2 x PKN5002
Then I can stop spending money.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 1:39pm
Remember amplifier specs are not Gospel..
Would suspect those supplied, are measured at 1khz, burst. Wink
osse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote osse Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2017 at 2:03pm
A bit more useful info on the other amp from the same brand.
http://www.bluearan.co.uk/index.php?product=JAM_Systems_B8_::_2_x_2500W_-_2_x_1600W_bi-amp&id=JMSB8
Short term pulse power ratings
Even if the 20-30% lower long term claim can handle sub at 2 ohm they are very good
Edited by osse - 09 January 2017 at 2:05pm
