new build, almost finished |
Post Reply | Page 12> |
Author | |||
johnEcash
Registered User Joined: 06 October 2015 Status: Offline Points: 19 |
Posted: 15 December 2015 at 11:03am |
Hi all,
A few months ago I started to build my own soundsystem with a friend of mine, it consists of 2 Double 15 inch wbins (800 w) and 12Inch mid + top just finishing up the paint and we are ready to roll Edited by johnEcash - 15 December 2015 at 11:25am |
AlmostSalty
Registered User Joined: 06 June 2011 Status: Offline Points: 415 |
Nice build!
johnEcash
Thanks,
the white areas on the bottom speaker are primer and will be painted black 2nd sub will be paibted the same |
bob4
nice to see someone build something off the beaten path!
How about handles on the wbins? They look like they're a bunch of heavy f*ckers! EDIT: Germany? EDIT 2: which drivers are going in? Edited by bob4 - 15 December 2015 at 11:44am |
Timebomb
Nice! Is this your own design? i dont think ive seen that layout before.
bob4
How high are you going to run the wbin? I guess you chose it to avoid seperate kick bins?
bob4
This plan has a similar layout:
http://www.dancetech.com/aa_dt_new/pa/plans/2x15-folded-print.gif
Edited by bob4 - 15 December 2015 at 12:19pm |
johnEcash
not from germany, belgium :p
we have a handle bar at the top of the wbins and we will add weels so we don't have to lift them as much. They weigh +-60 kgs without the speakers. the drivers we are using are: eminence delta 15lfa for wbin eminence Kapa 12 mid jbl compression driver highs How high are you going to run the wbin? I guess you chose it to avoid seperate kick bins? probably like the last picture, me might build some extra kickbins in the future, but for now this is how we want to run it. you think stacking 2 wbins like this would raise the 2nd one up too high? still learning what the best positioning is for these |
johnEcash
yeah looks like the same design indeed
bob4
ouch!
I was talking about the crossover frequency between the cabs Nice and simple little sound! What style of music will you play? Edited by bob4 - 15 December 2015 at 12:01pm |
johnEcash
aah i got you
w bins Cut-off lower: 38hz / 24 db upper: 140hz/24 db tops: upper: 20khz /24db lower: 140hz/24db the music we will be playing is tekno, acid, hardcore, tribe. we want to start some free party raves over here :p
Edited by johnEcash - 15 December 2015 at 12:07pm |
bob4
Hmmmm, I wonder if the cab could be redesigned for PPSL loading
but maybe the front chamber would become too big..... |
