new build, almost finished |
Post Reply | Page <12 |
bob4
Sounds good. It will probably fit that style of music well! Have you tested the wbins yet? |
johnEcash
Registered User Joined: 06 October 2015 Status: Offline Points: 19 |
checked a bit further and the dimensions listed above are the same as ours (not 100% sure about horn), we just left the back corners on our cabinet.
bob4
I have no experience of these wbins, but I suppose a short front loaded horn like this should kick well enough (but yes, that's only a guess). On Dancetech a lower cutoof of 55 Hz was mentioned, so it would probably be lacking in the subbass department if anywhere. That would be a problem with roots and dub, but probably works fine with techno If the stack is not high enough, you could rotate the upper wbin 90 degrees to get the midtop higher. Or maybe even rotate both wbins if you need to get a lot higher! Don't forget to use a ratchet strap though to fix the stack..... |
johnEcash
thanks for the info man,
what we need now is a crossover + eq or a processor (and yes the rest of the paint needs to be done) and we are running. amps are qsc gx5 for the top and gx7 for the bass cabs
