New compact bass design |
Post Reply | Page 123> |
Hemisphere
Posted: 09 February 2015 at 8:13pm |
As posted in the new projects forum. Should be good for 12v applications if it works anything like it sims (assuming I simmed it properly which is in question ;) .. and assuming the sim is reliable anyway as it's a very narrow pipe) http://forum.speakerplans.com/bass-pod-a-very-compact-budget-bass-bin_topic90694.html
Edited by Hemisphere - 09 February 2015 at 8:16pm |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Took me a few seconds to realise the measurements are CM not Inch!
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
"all panels are 0.6mm? 6mm you mean? little bit on thin side for screwing and glueing.
i may give it a go in the springtime, to cold for my half-outdoor workshop at the moment :-) will it need some delays when used together with a reflex system? |
Hemisphere
Of course I mean 6mm :D you're welcome to try 0.6 though - think of the weight savings!
I don't think it will need a delay - tapped horns usually don't (iirc). My knowledge is very patchy, just learning on a 'need to know' basis but if I understand horn theory correctly it should be very efficient when used in multiples. As a single box it's an uninspiring 92dB/watt (86dB/watt at 59Hz so more or less like a reflex, but as you can imagine in multiples it starts to act more like one big horn with the associated efficiency that gives - and a not too shabby 1.5 metre horn path! Note to self: Need to stop calling it a tapped horn. It's a tapped pipe. That's the line. No taper no horn. p.s. dear Mr. Danley please don't sue, thanks.
Edited by Hemisphere - 09 February 2015 at 10:23pm |
lutkeveld
Isn't this kind of a transmission line?
mini-mad
It not kind of a transmission line. It IS a transmission line..
mini-mad
The box is a nice idea if you wana give the little sub from your cheap pc speakers a new home..
i'd also try to recalculate for 9mm maybe even 12mm wood as with very little surface area and gluing the last side panel on your never to sure if your gonna get a nice air tight fit or not. still... lovely idea, i might upscale it for the tiny 8inch sub i have in my car........ ...... Edited by mini-mad - 09 February 2015 at 11:26pm |
Hemisphere
About it being a transmission line - does that mean it should be modelled or expected to behave differently to the way hornresp suggests? I think a 'tapped pipe' is not a standard variety of transmission line.. having a taper in the air path does affect the response but I didn't think it dramatically effected the behaviour of the box - lots of 'transmission lines' or tapped pipes are documented online with measurements consistent with tapped horn boxes, competing head to head in shootouts etc. Also, thanks! I hadn't considered how it might be flexible with other drivers. It's just a shame the Tangband sub drivers are SO deep.. if they produced a shallow magnet 5 inch with 11mm xmax.....:D Edit: It just occurred to me that in the current arrangement a small amount of the sound pressure from the back of the cone might end up going the wrong way.. (backwards up the left hand side) - there's some flexibility to move the driver forwards but that has a detrimental effect on the predicted response (not to mention the centre of gravity)
Edited by Hemisphere - 10 February 2015 at 2:07am |
davey t
Young Croc Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
Looks neat but surely you'd be better off with a larger more efficient bass driver in just a reflex configuration? Sorry to burst your bubble but just seems like a lot of build effort to me. The wood will make it heavy too.
Hemisphere
Depends what the design constraints are I would have thought. What I didn't mention is that it's designed for a specific application where space is limited to 4 boxes (can only be 4 - not two larger or one larger still) with absolute maximum dimensions as shown.
What can you suggest in reflex that would come close? A larger more efficient driver means a larger box and 10 litres external is the limit.
Have I misunderstood somehow about the efficiency gains afforded to an enclosure of this kind when used in multiples? As I say I'm really just going on what the sims say. Hornresp predicts a 6dB efficiency gain for each doubling of enclosures as opposed to 3dB with a reflex. Starting at 92dB for one box, 98dB for two, 104dB for four, etc. So 4 enclosures is equivalent to 4x 98dB per watt reflex boxes. Wall or corner loading the same four boxes would just accentuate that efficiency gap even further. So we're looking at 40 litres external, 28 litres internal and £54 in component costs for a four box system. The wood won't cost enough to stop it being cheap and the build is an effort for sure but the weight will be low - there's only the equivalent of a single 50 x 75 x 6mm panel in the whole thing. Edited by Hemisphere - 10 February 2015 at 10:44am |
Hemisphere
Edit: double post
Edited by Hemisphere - 10 February 2015 at 10:39am |
odc04r
It's an interesting little concept I give it that, I like the focus on minimal volume. It is a tapped transmission line so I would not necessarily expect much more volume than a reflex from it although that is of course going to depend on the driver a lot.
My first thought is that the size of the driver is going to obstruct a lot of air movement in the last part of the pipe, and as this is where half of the output must exit then that could be a concern regarding flow restriction. Only one way to find out! If I built it I would not bother with screws. I would rebate all the panels about 2mm so that the build all located together nicely and then ratchet it around every axis several times using 90 degree clamps. I have built a couple of HiFi cabs like this before and it works well as long as you have the rebates to get everything together without too much drama. Couple of panel pins could help if you struggled with it disintegrating before you could get all the straps on.
