New efficient neo system |
Post Reply | Page 12> |
Author | |||
Thomas Hosker
Registered User Joined: 20 June 2012 Location: East Sussex Status: Offline Points: 493 |
Posted: 13 March 2016 at 12:48pm |
Yo whats up guys, its been a while since ive played with batteries but im feeling the urge to start a new project for the summer.
So my plans so far is 1 x RCF LF18N401 18" neo driver on bass. Maybe a 150L reflex cab tuned to about 40hz, i would like a decent low end extension but i also dont want to be using to much of my precious energy on the power hungry low notes. For mids i have a load of P-Audio SN12-MB2 600w neo drivers, again lets keep it simple and compact. Nice little reflex cab but still plenty sensitive. For highs i have some old 18sound Neo 1" comps that will fit the bill nicely, just need some horns for them. (anyone got some old 1" cd horns they want to get rid of on the cheap?) For processing im thinking of using either MiniDSP of FreeDSP, whatever i can get my grubby mitts on sooner. Sub playing 40 - 80 then the mids can take over and i expect a crossover of about 2khz for the tops. Amps will be a sure 4 x 100w for the tops, ive used these plenty before and they fit the bill nicely, bit to much power but thats never a bad thing ayyy. Im abit undecided on a amp for the sub, maybe a 1 x 200w sure board? Any recommendations? Battery will be dependent on the event, if a car can reach the spot it will be hanging of a 110ah deep cycle, if not im playing with the idea of getting some A123 LiFePo4 cells to make a nice lightweight pack. The actual cabs should be very light, using neo drivers, 15mm BB ply and LiFePo4 batteries. Ill grab a sack truck and fashion some sort of loading system to hold it securely on for any uphill hikes. Ideally i want to build the enclosures like i would any touring box but just aimed more for weight reduction. Maybe use some ally bracing or something... The LiFePo4 battery pack will be self contained and separate, as will the amp/processing module. Therefor 1 guy pulling the 3 cabs on a sack truck will be easy, then another can grab the batteries and another amps. Oh and another 4 can haul the beer :) Anyone used the FreeDSP boards? Ill probably just go for a MiniDSP as its easier but i have to be careful of price on this one. Ill get designing some cabinets tonight and post up plots and plans later. Im located right at the foot of the south downs in Old Town, Eastbourne. If theres any other systems local that like deep dark rolling drum and bass, techno, tech house and any other bass heavy sounds let me know for a link up, oh and impromptu 12v clash :) Nearly forgot to mention there will be a 12-48v step up "booooost converter" inline before the amps but maintaining a nice 12v feed for the DSP. I will also allow a connection for a 400w pure sine wave inverter i have, this will be in a separate module and only used on rare occasions when battery power permits and we need to use CDJs, 1210s and DJM. Other that that all mixing will be from a Traktor S4. I cant wait to get on the hills and beaches with some nice tunes and sound quality/volume levels alot better than my shitty bluetooth speakers Edited by Thomas Hosker - 16 March 2016 at 6:58pm |
WWW.T8Audio.Com
Thomas Hosker
On second thoughts i dont have enough outputs on the MiniDSP to facilitate the sub output. I think ill have to go mono, use a 2 x 100w on tops and 1 x 200w on sub then stick some passive crossovers in the tops.
When using the MiniDSP and 2 amps do i need 2 pre-amps? So it goes Signal in > MiniDSP > pre amp > 1 x 200w sure amp > pre amp > 2 x 100w sure amp |
WWW.T8Audio.Com
Thomas Hosker
Bit of an update,
Ive ordered a nice beefy 1200w boost converter, the one in question had some good reviews and its a bargain price so ill give that a go. Ive also just ordered a 2 x 300w TAS5630 amp board, this gives 2 x 200w @ 8r. For the moment ill run the system mono with a single 18 + 12 and 1" on a passive crossover. This also gives me the possibility to expand in the future and add a TK2050 for tops, giving 2 subs and 2 tops in stereo. Ill grab a miniDSP board i think just to keep things simple. Anyone got one for sale? :) Im also looking at some nice waterproof cases from CPC for the amps and batteries etc. If theres any CPC voucher codes floating about let me know, this is very much a budget project thats getting quite expensive :( Oh and ive sourced some LiFePo4 pouch cells for about £20 each, there 20ah and 3.2v each. |
WWW.T8Audio.Com
Thomas Hosker
Is there a 2in 2out DSP board thats around the £20 mark?
WWW.T8Audio.Com
Thomas Hosker
These look interesting...
http://www.ebid.net/uk/for-sale/linkwitz-riley-opa2134-2-way-active-filter-by-kmtech-assembled-tested-141304014.htm |
WWW.T8Audio.Com
komotive
Registered User Joined: 17 March 2016 Status: Offline Points: 13 |
Have you worked out your running time from the rig? Interested to see what the battery pack size is!
slaz
Any mention in the reviews of switch-on current inrush ?
The 5630 amp will need 48-50V to deliver that power .... and thats way too much for the 2050 board. Another DC-DC converter ? If so, that'll add even more to the switch-on current ....
Not so sure about simple .... it'll need yet another DC supply voltage. In the field tweaking will need a laptop all the time ..... and not sure about ground loop issues ..... |
Thomas Hosker
Disregard the TK2050 idea, i hadn't thought that through. Ill stick with the single amp
Whats the best options for a crossover network then? |
WWW.T8Audio.Com
Thomas Hosker
Minidsp is 4.5~24Vdc input via header (150mA @ 5V) according to there PDF file. So should be fine just off the battery?
WWW.T8Audio.Com
slaz
Well - you need to think through pretty carefully - otherwise you can waste quite a bit of money and time. Re crossovers .... good question - I've looked into various possible solutions - and none are easy/straightforward TBH .... (well apart from using car amplifiers) That board you linked to - may work well - BUT .... a) Its a fixed frequency thing so you'll need to know frquency before you order (well - can be changed, but will need some soldering/faffing around a bit) b) Its mono - you'll need 2 for stereo c) It needs a split rail supply .... if using 24V battery, you'll need to DIY up a virtual earth circuit for it ...... which might then chuck up ground loop issues (maybe) - might need ground loop isolators - all this adds up to extra complication/wiring/switching/stuff to go wrong. |
Thomas Hosker
assuming its ok to run a miniDSP off the 12v battery with the boost converter on there as well ill just do that. Leaves me some flexibility in the future to add more channels too. If not, can i put a 5v step down for the miniDSP?
Ill build the cab/s and then workout any passive x/o before making them, i may just use 2 outputs of the minidsp to have a 40hz high pass and 80hz lowpass on channel 1 and a 80hz highpass on channel 2 with a passive for the 12" and 1". Got a nice long weekend ahead so hopefully ill make some progress |
WWW.T8Audio.Com
studio45
I use the KMTech boards for crossovering, available on eBay - he has several flavours; I've got them running straight off the battery voltage with a virtual earth circuit for the 0v rail, then capacitor-coupled at the outputs into a 2x300w Sure board. No ground loop issues - you don't need to connect the ground between thecrossover output and amp input.
I'm using a 3-way board configured with 50Hz and 100Hz points - so I drive my sub from the "mid" output, and it recieves 50-100Hz, and the mid-tops from the "high" output, and they recieve 100Hz+. I haven't found a crossover board with a freely configurable highpass on the input, so this is my workaround. I'm still not on the miniDSP hype, it just costs too much for what it does. FreeDSP is *much* more interesting ;)
