New kick bin for PD186 : SV186BPH |
Post Reply | Page 123 10> |
Dref
Registered User Joined: 05 April 2010 Location: Denmark Status: Offline Points: 287 |
Posted: 04 February 2013 at 9:10pm |
Hi Speakerplanners
I just finished building two of my new band pass horns optimized for PD186. Dimensions are H:636 W:600 D:750. So they stack nicely on top of 600 or 636 wide subs. Here is a simulation of 4x ES18BPH (Black) compared to 4x SV186BPH (Gray), both loaded with PD186 given 0.25W per cap(1W in total) in 4 Pi. The original driver recommended for the ES18BPH sims much better than the PD186. The sim might also be too pessimistic because people seems satisfied with PD186 loaded ES18BPHs, but at least this were my motivation for trying to do a new design. A 3D rendering of what the cab should look like when done. (At least that is my current plan) I have plans as a pdf if anyone is interested. [Download link:uploads/7894/Plan_-_SV186BPH.pdf] Now for some more pictures(As usual, sorry for crappy phone pictures): Edited by Dref - 12 February 2013 at 10:56am |
A proper build subwoofer will be the only thing in a room that is not shaking.
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
looks like my new kick cab good work m8t....
bee
Looks very much like we were both on the same wave length of thinking.......
ermita
Young Croc Joined: 19 August 2010 Location: Surrey, TW10 Status: Offline Points: 1266 |
nice Dref.
Dref
Haha you are right. Nice work to you too Are yours also designed for the PD186?
Edited by Dref - 05 February 2013 at 1:09pm |
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
Edited by T-Bone - 05 February 2013 at 10:25am |
BASS, how low can you go!
bee
Yes, the joy is they play higher before the sound honky, they play with ease up to 175hz
SBC
Registered User Joined: 25 November 2010 Status: Offline Points: 1266 |
the rear facing driver will be an issue for playing up anywhere above about 150
F.T.S.S.
bee
This is what I was led to believe, but so far test I'm doing are on the positive side. Ill keep u posted on how I get on and ill try to get some Rta plots up
Teunos
Considering the opposite, although turbulences will occur around the chassis and magnet etc, the rear of the chassis will also act as a phasing plug.
Best regards,
Teun. |
Dref
Oh I found out I could use the upload file function.
Plan: Consider the cone shape vs the chamber shape. Reverse firing = >> Normal = <> Minimizing the path length differences. Not that I think all this really has a significant impact. Even at 200 Hz the wavelength is still 1,72 m... What is important is the volume and length of the front and rear chamber. |
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
Both looking cool!
**Heavy Weight-Line**
A home without books is like a body with no soul. |
