  New Posts New Posts RSS Feed - New Line Array Project
csijo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csijo Quote  Post ReplyReply Direct Link To This Post Topic: New Line Array Project
    Posted: 07 January 2011 at 10:15pm
Hi Guys..
I am about to start my new build, is for 4 or 8 speakers line array type but i'm just a little in doubt  what is better to make it..
To get more spl and sum and align the sound of the boxes what horn is better the pyle nexo clone the dayton wave guide or build the horn with wood in the box i will apreciate the help of the specialistes yours. Thanks
Audio Fanatics, Bass lover
Post Options Post Options   Thanks (0) Thanks(0)   Quote csijo Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2011 at 10:32pm
The links for the Horns and drivers are here:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=270-314
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2576#windowcontent
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2546#windowcontent
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2504
http://www.pyleaudio.com/itemdetail.asp?model=PDS122
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-442
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2011 at 11:23pm
First of all you need to learn the science behind line arrays.
Your choice of hf horns clearly speaks that you have no idea what you are into.
Edited by MarjanM - 07 January 2011 at 11:27pm
Production and R&D Manager
Bold Audio Inc
www.boldaudioinc.com
http://www.facebook.com/pages/Bold-Audio-Inc/323691856723
Howbig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howbig Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 1:04am
Agreed, obviously dont no what your gettin ypurself into bungin any driver in a box
Post Options Post Options   Thanks (0) Thanks(0)   Quote csijo Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 12:49pm
Hi how it goes
You are right I am not a specialist in line arrays, the audio  is my hobby but I have read several papers that talk about the beginning of the line array, about 80% of the horizontal space of the box should represent the transducers and also required 4 boxes per side for the physical principle of the line array begins to take effect, which requires a plane wave generator for high frequencies, which is also simpler to make the case for placing the two midbass very together in an asymmetric shape. I was DJ in the 80s and manufactures horns at that time and resume my hobby about 9 years ago and I've made about 40 boxes at that time, several models of speakers for subs and full range. The biggest problem is that here in Venezuela not get the plane wave generators and would be very expensive to achieve. These boxes are for my hobby and would use occasionally for familiy and holidays partys or listen music in my house or for put audio for a small band,
I will accompany  these boxes with 4  Turbosound subs and a ALTO MAXIDRIVE 3.4 to adjust and equalize the system. I just hope to try to get the best sound of these boxes with few supplies and resources we have here in Venezuela.
So I would like to know that the horns  of the two models will do best considering  for not having the plane wave generator
They are also available for using these two models of horns:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2578
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=270-304
Thanks I will appreciate it your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 12:57pm
You obviously dont get it at all.
You need a horn with 90 to 100 degrees horizontal dispersion an 7 to 15 degrees vertical dispersion.
I already give you an idea how to make them by your self.
Bold Audio Inc
Post Options Post Options   Thanks (0) Thanks(0)   Quote csijo Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 1:15pm
Yes thanks you very much and I saw the wood design with the two drivers eminence, you showed me, i will made that model  exactly if i have the appropriate measures for a box  using midbass  8 ".
Llet me show someting that i was work thinking in that
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 1:23pm
st of all you have to know what you are doing. here are some more pictures of the boxes i did. they are with 12 inch mid/low. for 8 inch drivers you have to make your own dimensions. just keep the horn at 10-15degree vertically. That will determine your horn length.
Edited by MarjanM - 09 January 2011 at 1:26pm
Bold Audio Inc
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 1:25pm
Bold Audio Inc
Post Options Post Options   Thanks (0) Thanks(0)   Quote csijo Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 1:52pm
Thanks again see this model that was working
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 4:37pm
I don't know if you actually know anything about wave guides at all, but that isn't how a waveguide was supposed to work. In your drawing there is absolutely no function to the fins.
The fins are supposed to time allign all the waves running through each individual channel creating a uniform wave front.
like this:
Or something which is easier but which math says works as well (the main flare being a parabole)
butterfly hornbutterfly horn
Edited by Teunos - 09 January 2011 at 4:39pm
Best regards,
Teun.
,,Diamonds are forever''
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 7:02pm
Teunos, dont add oil to the fire :-)
That turbosound waveguide is very hard to diy. So any wg is better than none.
All that wg thing is very good in theory but difference is not that big in reality.
Bold Audio Inc
Forum Software by Web Wiz Forums® version 10.11
