New P Audio 3 inch neo driver |
Post Reply | Page 123> |
Hemisphere
Posted: 05 November 2014 at 2:03pm |
Just spotted this on Blue Aran: http://www.bluearan.co.uk/index.php?id=PAUSN330N
Could it be the fabled Minirig driver? The plots seem to suggest a phenomenal efficiency (touching 100dB/watt in places) |
Timebomb
Id take p audio plots with a bucket of salt.
Hemisphere
Same, but I trust Minirig plots.
lost eden
Young Croc Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
As I've said in other threads, without actually dismantling my Minirig I am still 99% sure that it is a Tang Band driver, simply by the style of surround/adhesive visible through the grille. And without dismantling my Minirig Sub I am 100% certain that is a Tang Band driver (W3-1876S or similar).
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
There's something horribly wrong with that plot. According to that the driver has 20 ohm impedance, so something is definitely not right. Also average sensitivity is rated at 86dB/W/m which is always averaged in the listed usable frequency range, ie. 100-18000hz.
But you're right that the plot is virtually identical to the Mini-Rig plot so it's quite safe to say that it's the right driver and not a Tang-Band. Probably a OEM version with black cone.
Edited by Saturnus - 05 November 2014 at 3:36pm |
lost eden
If the image on Blue Aran is correct, this driver looks nothing like what's in the Minirig. The one in the Minirig has a smooth cone material (not woven carbon fibre like the P-Audio) & as I said the surround is a dead giveaway - the glossy ring on the inside of the santoprene is diagnostically a Tang Band feature & the Minirig clearly has it if you look closely.
Hemisphere
Yes the smooth cone material was what I gathered from looking inside the grille holes, but those plots look too similar to be coincidence. Possibly a custom OEM variant is used in both cases?
Edited by Hemisphere - 05 November 2014 at 3:43pm |
Saturnus
Agree. Very definitely a Tang-Band (in that picture... but that not the Mini-Rig driver though). Conical dust cap is another give away. Question is why is the plot published by Mini-Rig then for the p.audio driver? If you overlay the 2 plots they are identical. And I don't mean they are really really close to being the same. They are 100% identical. In fact, the Mini-Rig plot is just a copy/paste of the p.audio drivers data sheet plot. Even the impedance plot is exactly... and I do mean exactly the same.
Edited by Saturnus - 05 November 2014 at 3:58pm |
Hemisphere
The image posted isn't a Minirig it's just a tangband driver.
Saturnus
Makes more sense then. Ok. Then unless someone does take the Mini-Rig apart. All indicators point towards the p.audio driver.
Hemisphere
I feel like it's kind of faux pas to give the game away, but 3 years is a very good run totally uncontested and there's obviously a lot more to it than good driver selection (besides the circuitry and enclosure design, by all accounts the customer service and after sales support has been stellar).
lost eden
The reason I posted that picture was to show the giveaway glossy ring on the surround, which all 3" full range drivers from Tang Band have & which the Minirig clearly has if you peer through the grille.
