New system design... |
SmokeyJoe
Young Croc Joined: 22 August 2006 Location: United Kingdom Status: Offline Points: 534 |
Posted: 23 June 2016 at 11:40pm |
Hello people, I posted a thread in the general forum regarding this... Heres a link!
But basically, I want to build a new rig. A serious one this time! I may have to buy the bits as I go but at the moment I would just like some input with the box choices etc. After loads of reading and researching on here, I have come up with a dream rig. It would be: - Turbo Floodlight Mid/Tops - Martin 215MK2 Kick/Low mid - Scoops ? or maybe a FLH design of some type for sub. Probably start with 4 subs, 2 kicks and 2 mid tops to make 2 stacks but aim to keep building boxes to expand the system. It would be nice to do festival tents/stages at some point in the future. Theres a group of us so the plan is to build this and finely tune it to our taste and genre of music (Drum & Bass) like a proper (roots etc) sound system. Dnb has long heavy basslines similar to dub/reggae/roots which is why I'm thinking scoops for the sub? Valve use them (RX18) I think. Martin 215MK2 for the low mid as it can play higher than most due to straight-ish horn and Dnb kicks and snares are in the 90-220hz range. This is important stuff. Turbosound Floodlights because they are praised on here and I wouldn't be able to build anything better! I'm going to need to find someone who could build me some 215 copies and recommend a good driver to load them with? Any input would be awesome! Thanks, Joe.
P@Freak
Registered User Joined: 09 June 2013 Location: Germany Status: Offline Points: 51 |
Use Martin 115 MK >> 3 << it is the better Horn ...
and under this you con run regular better modern deep tuned double 18" Bass Reflex. Scoops under those great Mid-Horns makes no sense ... P@Freak
