  New Posts New Posts RSS Feed - Newbie question. Where to start?
Majestic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Topic: Newbie question. Where to start?
    Posted: 14 January 2012 at 11:11am
This will be my first build of a 12v system.
I'm using a leisure battery to power 3 amplifiers, one for sub, one for mids and one for tops.
Not sure how to start wiring this thing up. What can you guys recommend for connecting 3 amplifiers, a crossover and stereo to one battery? Should i make a little fuse box?
Also, on the amplifiers there is only one battery connection, the others are remote and ground. How should i connect positive and negative terminals of the battery?
Thanks in advance!
Falun Dafa Hao!
portapartyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote portapartyman Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2012 at 11:05am
67 views and no-ones helped you!!!
I'll just quickly skip over this.
GND = Negative
Remote = positive feed for switching on eg. you can fit a switch from positive to remote to switch amps on and off
Fuses - if the amps are fused there's no need to fuse them again although you could fit a large fuse for the whole system at the battery to protect everything in the event of positive and gnd coming in contact (this shouldn't happen with sensible cable runs)
3 amps and one Battery. In my opinion that sounds like it wont last very long! I would personally use one amp and crossover passively but others on here may think differently. By all means crossing over seperatley will get a much better sound but with one battery you're not gonna get many hours out of it!!
Hope this helps
4 Wheels, 2 Decks, 1 mixer and 12 Volts. The Porta Party entertaining festival crowds since 2007 www.theportaparty.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2012 at 2:55pm
Thanks alot
Falun Dafa Hao!
MessTek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MessTek Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2012 at 3:30pm
im at work at the mo but ive done nearly what you are talking about nearly but with two speakers once i get home il set it up and post a quick snap, once you see how to wire it its obvs and your never forget it,
Stomp-Tek facebook us
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2012 at 4:43pm
Thanks in advance!
it might be worth looking at a passive crossover for your mid/high point, instead of using 3 amps you can then use just 2.  car amps use a lot of idle current (sometimes more than 1A per amplifier).
certainly add a fuse near the (+) battery terminal!
maybe put some spade connectors onto the ends of your power wires so you can daisy chain the amps.
finally, if your amps have built in high/low pass filters see if you can use them instead of adding an active crossover.
Forum Software by Web Wiz Forums® version 10.11
