Newly purchased Turbosound TMS-4 |
Post Reply | Page <1234 6> |
4D
Thanks(1)
Those cd102's are notorious for corrosion they are the only component that is partially open to the elements. To save a lot of money I would be very wary of putting any new diaphragms in until you are totally totally and again, totally certain that you have cleaned out the coil gaps on the compression drivers perfectly, no roughness, no grit, no welded on fragments of the last coil. Otherwise as you can imagine in go the new coils a couple of shows later & oop's coil carbonara.. A piece of credit card works well as a scraper followed by some masking tape doubled over sticky side out and run round the slit till its picked up all the bits of crap.. |
shagnasty
Thanks(1)
slaith
Registered User Joined: 30 December 2010 Location: Sweden Status: Offline Points: 74 |
Hey!
So you were the guy that bought the TMS-4:s, saw the ad a while ago.
A slight twitch in the buy finger but decided not to in the end.
Those cabs actually look pretty well taken care of, have alot of fun with them.
Where abouts are you located?
And since you have them apart already.
I would sugest for the greater good of all mankind, get som pictures and maybe measurements of the Turbobass chamber.
Because there has been so much speculation on how it's made up and what it looks like and so on.
I think alot of people would be really grateful, I know I would atleast.
Best regard
Patrik J
Hyppe
Registered User Joined: 08 September 2012 Location: Sweden Status: Offline Points: 19 |
Im working hard on the cleaning process, took the opportunity to remove even the functioning one for cleaning. Tape, creditcard, vacuum cleaner & crc Electronic Cleaner is the shiet :) http://200sx.kicks-ass.net/djhypnoz/img5053369cd717b.jpg This Youtube vid is nice for noob´s like me: http://www.youtube.com/watch?v=Tfh-OvJ1o-Q&feature=share&list=UUwCFRpw-O1RO3dlUA9is5gA Edited by Hyppe - 14 September 2012 at 3:10pm |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
I have a few cd-102 with the blue turbo back & badges, and 4 b&c de 25 that I don't use in denmark.
Yes they use this beyma 350-16ohm diaphragm, if you're using passive filters notice driver ohms will affect crossover frequency, check updates for filters by turbosound, I have a link somewhere... I have filters too, my tms-2's are now 3way speacon8, just tested a few tonight! |
Hyppe
Pm me for Price!
But Original HF drivers are already 16ohms? so no difference? Btw: 3way speacon8 is on the way on my TMS-4 to :)
Hyppe
I have now restored the speakers and for the first time tried their performence, Wooow :) I can only say that I am more than satisfied! I find it very difficult to see what you could get that is better for this amount of money
Now, however, the search for bass cabs started. what do you think (and why) is the best bass cabs to combine with Turbo sound TMS-4? |
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Online Points: 2155 |
Thanks(1)
Tse 118 or tse 218. Basically the same as the bottom end you already have at the bottom of the TMS 4, so no more processing required, just adding more. Run them 30 to 250
shagnasty
If you add more bins a 80Hz hi pass on the TMS kick section gains you a load of efficiency, so you can really drive the bins low and get maximum punch from the TMS, IMHO TSE-x18 is not the ideal box to sit under a TMS-4 as you want something that runs harder and lower than the existing 18", unless you go 8 TSE-218s aside in witch case they go loud and low....
Hyppe
it's really hard to find Turbos here in Sweden....
If i want to build something myself, what do you recommend then? And please explain why you recommend it. Im after all-round system! (but if i have to choose i want it to sound best on Psy, house, techno, disco. it have to works for liveband to!) |
slaith
Thanks(1)
Hogs maybe? Since the 18 in the TMS-4s will meet properly.
Myself I'm beginning work with the MHB-46 designed by Marc.O I think jerronimo here has built 4 of them and swears by them so that's the way i'm gonna go for allround subs. Though that's a hybrid horn so I suppose a little different sound from FLH:s, I don't really know since I've never heard eather. But that's the conclusions I've drawn myself. Maybe somebody else with more experince has some different input. Patrik
Hyppe
Hello Again!
Since last time I got myself a Dsp (BEHRINGER DCX2496) Yesterday, I set up the TMS-4 for some tests. What I noticed immediately is that Hf Turbosound CD-101 (Beyma CP-300) located in two of the boxes sounds very different from the B&C driver (BBC D20) located in the other two boxes. Beyma cp-300 sounds much softer and more comfortable but you have to +db around 10 000 for them to come out properly B&C driver sounds very sharp "tick tick" :) from the start. so this one you must instead reduce a lot db to get it to sound good. i dont know how to do here? 1. Try find two more Beyma cp-300 cheap 2. I can buy four Beyma cp-350ti (8ohm :/ ) cheap from a guy in Sweden 3. something else I was also looking for low bass speakers to complement the bottom with my TSM-4, but realized that I already own a good low bass speaker myself, since it's about low bass 40-80Hz, bandpass boxes very effective here and since I already own two pieces active bandpass enclosures (The Box TA18) (131db spl) I decided tested these out and they play very good low bass down to 40-50hz and is thus the most for your money when I just need to complement the two extra. Now I have tested these together with TMS-4 and they have no problem keeping up with the TMS-4 (rather the contrary). I use the Dsp (BEHRINGER DCX2496) but i keep the passive x-over in TMS-4, why you ask? 1. Save some money to only use one 4-channel amplifier 4x810watt 4ohm (t.amp TSA 4-700), need one more amp to go full active 4-way. 2. Need modifies to the TMS-4 to get them active 3. Need dsp on the active lowbas (The box TA18) So now i use it like this: x-over 40 - 80Hz The box TA18 (+9.5db and 3,6 delay to match the TMS-4) 80-250Hz Tms-4 bas 250 - Hz Tms-4 mid hf Anyone know how i in the future get the DCX2496 to work 4-way active, guess i need some more dsp? Edited by Hyppe - 23 January 2013 at 12:24pm |
