  New Posts New Posts RSS Feed - NightFire Scoop Plans
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Topic: NightFire Scoop Plans
    Posted: 13 December 2006 at 11:53am
Apparently for their 20" Driver, which they say can be dropped in
same box as PD186, but just needs larger cutout.
nightfire_nf-scp20_rear_loaded_horn.pdf
However, what would 1850/V18-1000/V18-1200 sound like in this box?
EDIT: Just spoke to the designer (Ian) on his moby, and he recommends
PD186
18PZB100
FANE
He says the following work, but extra dosh isn't justified.
18 Sound (Don't know which one)
18TBX100
He didnt mention PD1850 or V18-1000.
Edited by levyte357 - 13 December 2006 at 12:14pm
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2006 at 1:27pm
it looks very compact
CELTIC SUBSONIC SOUND SYSTEMS
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2006 at 1:41pm
Nightfire says:
20" Scoop / Rear Loaded Horn - Are your 18" scoops not loud enough?
The PR20120 in this relatively easy to build scoop design will BLOW YOU AWAY! 500W AES, 1000W Continuous, very low power compression and unbelievable sensitivity gives you MORE BASS from a cabinet no bigger than a 'standard' 18" scoop.
The 20120 really is a unique bass driver due to the way it behaves under power, giving you a 'truer' sub bass response, and insane SPLs! You won't be dissapointed...
SmokeyJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2006 at 7:47pm
What difference does it make having a straight bit of wood where the scoop normally would be?
I've heard it gives the sound more KICK is this the case?
Thanks, Joe.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2006 at 12:54pm
I recon the sound will be sharper without the scoop part making the output smoother.
