  New Posts New Posts RSS Feed - NL8 wiring standard?
Max_SPL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max_SPL Quote  Post ReplyReply Direct Link To This Post Topic: NL8 wiring standard?
    Posted: 27 November 2012 at 8:38pm
Could any one let me know if there is any standard for wiring NL8 connectors I.e are pins 1+ and 1- used for the highest frequency component or the lowest frequency component or is it just user choice? Is suppose the same question could be asked for NL4 connectors
rich21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich21 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 8:46pm
1 = low
2 = low mid
3 = hi mid
4 = hi
always the lowest fr 1st
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max_SPL Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 8:47pm
Hmmm better change my wiring then
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich21 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 8:51pm
does it matter?
if your speakers only go out with your rack then no
Rich
tall_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tall_mike Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 8:52pm
oddly enough, a lot of people go with:
1: bass / mid
2: mid / hi mid
3: hi
4: sub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max_SPL Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 9:03pm
Well You never know where your kit might end up,and if there is some standard as there appears to be it always better to try and adhere to it
Thanks for feed back guys
jbinks-v2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbinks-v2 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 9:12pm
The standard is lowest freq first, as already mentioned above. This is from Neutrik's own documentation.
It matters because most large system tops are wired "top down", so if it's a 3-way top, the NL8 input will only be connected on pin sets 2, 3 and 4.
1 will be left so you can pass a bass signal through.
A 2-way top would use 3 and 4 (or just a NL4 input).
Hope this makes sense / helps.
Cheers,
John
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 9:19pm
Most systems pass the sub on pins 4
www.deltastarevents.com
www.dss-audio.co.uk
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 9:34pm
Originally posted by rich21 rich21 wrote:
1 = low
2 = low mid
3 = hi mid
4 = hi
As someone said if you ALWAYS use your own rack doesn't matter much, but all systems I've ever used, as said by others, pass from lowest to highest including sub as shown, not with sub on pin 4.
The main reason for this, apart from compatibility, is safety in terms of protecting your drivers.
Keeping your comps and HF up at +/-4 means your a lot less likely to accidentally throw a wrong and far too powerful signal at it and blow it to hell, where as any wrong signals will most likely get thrown to the subs or lows on +/-1 and be able to handle it.
With NL4 connectors its a bit more varied, some companies assuming you'll use "full range" tops on their own and wiring on +/-1 with an internal crossover, some like Nexo on +/-2 to let you pass/pass-through sub, and then some biamped so using both connectors.
k
Edited by kevinmcdonough - 27 November 2012 at 11:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 9:48pm
Yes kevin that has always made me wonder why they do it like that. But i am just going on what i have found with the majorty of the nl8 based systems ive used.
Surely when you are running larger systems like this you will have seperate lf racks anyway.
www.dss-audio.co.uk
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 10:04pm
Do something completely different lol
1 Sub +
2 Bass +
3 Mid +
4 High +
5 Sub -
6 Bass -
7 Mid -
8 High -
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2012 at 11:38pm
Surely when you are running larger systems like this you will have separate LF racks anyway.
Not always. Not having worked on scoop systems much they may have all their LF amps in one rack, but racks for more standard rock music and big hire companies will usually be mixed.
Partly this spreads the power load out through the racks rather than having one big rack drawing 40 amps and the rest tickling along on 5, but it also makes it very modular.
So if each rack has say one sub amp, one mid amp and one HF (or whatever ratio is needed for your system) then you can just take one rack for a small system and have a complete set, two racks to double everything for a bigger system, and so on....
k
Edited by kevinmcdonough - 27 November 2012 at 11:39pm
Forum Software by Web Wiz Forums® version 11.07
Copyright ©2001-2016 Web Wiz Ltd.
This page was generated in 0.062 seconds.
