One more limiter settings thread |
Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
Posted: 04 July 2013 at 10:06am |
Hi all
With my previous speakers, setting limiters was just to keep my amps from clipping since the powerhandling of the drivers was very hight. With my new Floodlight system, i have enough power to fry very expensive drivers. Speakers: TSW-718 - 800 watt RMS @ 4 ohm TFL-760ht - mid= 250 watt rms @ 8 ohm, hi-mid = 100 watt rms @ 16 ohm, hi = 50 watt rms @ 16 ohm Amps & DSP: Omnidrive FDS-388 Sub amp - Ram Bux 3.4 = 2x1750 watts @ 4ohm. Voltage gain = 33.1 DB Sensitivity @ 4ohm = 2,25v Mid amp - Ram Bux 2.0 = 2x950 watts @ 4ohm. Voltage gain = 33.1db Sensitivity @ 4ohm = 1,33v Hi-mid + hi amp = Labgruppen FP2400Q = 4x370 watts @ 8 ohm Voltage gain = 32db Can someone please point me in the right direction. Using different spreadsheets found online gives me different results. Thanks for your time. |
simonh
Old Croc Joined: 07 November 2010 Location: Essex Status: Offline Points: 1773 |
Far from an expert pal but from a mathematical approach, I used the following model, however, I have never had this verified. So please do not take this as gospel as I wouldn't want you fry your drivers becuase of my incorrect calculations. I just hope it helps point you in the right direction:
chille
Registered User Joined: 01 August 2012 Location: Sweden Status: Offline Points: 12 |
"Transducer Voltage limit 800 RMS @8R 37.27 dbu" I also have the same problem. I will probably develop a Javascript to do the calculations for me. I will put it online and post the link here (probably in the weekend), if I manage do do something useful. |
simonh
Sorry spelling error on my part. This is how I done the calculation: Transducer Voltage limit 800 RMS @4R = 20 log (SQRT(800*4)/0.775) = 37.27
Maybe one of the expert members will come along and confirm.
dsound
Registered User Joined: 25 September 2011 Status: Offline Points: 19 |
Use this might help http://www.funktion-one.com/settings/
Hvedstrup
Thanks for all the good information. Just one more noobish question. Are all calculations and numbers done with the amps turnes all the way up?
simonh
Goodvibetribe
Young Croc Joined: 06 December 2011 Location: Cardiff Status: Offline Points: 959 |
Simon: those setting look correct to me and the formular is correct You do need to remember that most limiters wont allow for decimal numbers (Sometimes maybe .5's) So it is always the safest practise to round down.
Chille: Turbosound have produced an excel file with one in already. If you ignore the turbosound stuff it works for any other speaker/amp combo. www.turbosound.com/upload-files/File/technical/dsp/dsp.xls
George c - www.gorilla-audio.co.uk facebook.com/gorillaaudiohire
4D
How many boxes per channel ?
bwilbee
Registered User Joined: 29 October 2007 Location: Isle of Wight Status: Offline Points: 318 |
Turbo boxes have very conservative rms ratings, i routinely run them at program power not rms power, the following is from the floodlight data sheet:
LMF: 250 watts r.m.s., 500 watts program, 625 watts peak HMF: 100 watts r.m.s., 200 watts program, 250 watts peak HF: 50 watts r.m.s., 100 watts program, 125 watts peak Recommended amplifier power: LMF: 500 watts @ 8 ohms, HMF: 200 watts @ 16 ohms, HF: 100 watts @ 16 ohms
tcourtneyvincent
Young Croc Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
Im running my floods off the following amps
100w at 16ohm per side for the HF 275w at 16ohm per side for HMF 550w at 8ohm per side for LMF I occasionally can flick a clip light when pushing the system to the max and the floods are fine. You wont need to limit any of your amps mate. |
