opinions on class H amps? |
| Author | |||
B.M.F.
Joined: 09 January 2012 Location: Muncie IN Status: Offline Points: 136 |
Topic: opinions on class H amps?Posted: 11 July 2012 at 5:09am |
So what do you think of them?
Are the "best of both worlds" claims true? Do you really get "AB sound" without sucking the outlet out of the wall at high levels? Ok if you still use class D on bottom? In my personal experience. I still see my voltage meters bouncing like a yoyo when feeding my QSC's but to be fair I am driving my subs with them and being in the states I rely on that wonderful 120V power. Opinions? |
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 2061 |
Posted: 11 July 2012 at 2:34pm |
Class H has been around for a long time (eg Crest Pro series 7001, 8001, etc.) and are pretty standard for high power amps. I´d be more doubtful about the Class D...
![]() Edited by Earplug - 11 July 2012 at 2:34pm |
Muckerbarnes1
Joined: 20 March 2010 Location: Stroud Status: Offline Points: 1994 |
Posted: 11 July 2012 at 11:47pm |
Most class h amps are fine. I prefer large AB amps. Rail switching and similar just mess with the sound.
For you though things are different. 120V is a low psu for a big amp. Class H for you. No class D. Yuk. |
Billy Dawg. Best Avatar yet!
B.M.F.
Posted: 12 July 2012 at 3:06am |
Not using class D. And yes I know they have been around for a while. I've been using QSC for years. I just think the claim that they are that much more efficient is off base. Like I said in the opening post, I bounce the voltage with every pop of the kick. Is there really that much of an advantage to switch railing. The old heavy as a tank peaveys I had 20 years ago didn't seem to be any worse on power and quite frankly sounded better. Although I'm sure QSC has saved me a fortune in chiro bills.
Joined: 02 April 2004 Location: United States Status: Offline Points: 2438 |
Posted: 12 July 2012 at 4:45am |
Hi. It appears you do not have a good understanding of the current limitations in your line of work. Using a standard 20-amp circuit under a, 120-volt line source would not enable you to use a Peavey Class AB amplifier if it offered the same wattage of a QSC class H amplifier today without tripping breakers. Coincidently, two Peavey CS 800 (Class AB) bridged mono (2400 watts total) can/will trip a 20-amp 120-volt breaker. This is why the QSC RMX 2450 is Class H and not Class AB. You are using your Class H amplifier for bass. Bass frequencies require more current than high frequencies. So it is not uncommon to have an amplifier used for bass as you put it “bounce the voltage with every pop of the kick.” The Peavey’s offered DDT which was always enabled unless you physically turned it off. If you are rock person, the compression used in the DDT may be the reason why you prefer the sound of the old Peavey’s playing bass more than your new QSC amplifiers of today. Best Regards, |
Tony Wilkes
Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4125 |
Posted: 12 July 2012 at 5:04am |
Elliot, as always a sensible answer :)
Tony |
www.forteaudio.eu - BMS - db-Mark Processors
Earplug
Posted: 12 July 2012 at 10:30am |
Class H will also keep the o/p devices cooler, so longer life.
B.M.F.
Posted: 12 July 2012 at 10:49pm |
I'm very aware of the necessary current. I have always used independent 30 amp(120V) circuits on my bottom amps. It was in fact 2 cs800's bridged per circuit back in the day and they held a much more stable load (and never tripped) than a single QSC 2450 on the same circuit. This was exactly my point. It shouldn't do this. The QSCs should not be pulling this kind of a load. I would agree the DDT compression may have been helping the Peaveys with the gain reduction it creates but regardless the QSC amps should not be working this hard. To be fair some of my QSCs are pushing ten years old.
So is class H really running that much more efficiently when pulling low frequencies? |
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 2479 |
Posted: 12 July 2012 at 11:52pm |
Difficult to really compare the two topologies because different manufacturers will design-in different performance at different impedances and currents. With a low impedance load, running a high-current bass duty, the current rating of the amp is going to be more important than the voltage swing..surely? Macrotecs sorted it in their VZ circuitry to give the best of both worlds...others did a similar thing with a manually operated impedance switch eg MC2, Lab etc.
North Staffordshire |
Posted: 13 July 2012 at 1:40am |
Once the amplifier is being driven at the given impedance load, at the desired output level, the amplifier is going to draw current. The only reason to use a higher ampere rating (30 amperes –vs- 20 amperes) is to lower the chances of tripping the breaker.
I wasn’t referring to the DDT enabling the amplifier to draw less current. The DDT alters the sound once activated which, could be the reason you stated…
Two Peavey CS 800’s, bridged mono, @ 4 ohms on a 120-volt line can/will draw 30 amperes continuous. The QSC RMX 2450 cannot exceed 20 amperes continuous @ 4 ohms bridged mono on a 120-volt line without current limiting taking place. Peavey CS 800 does not offer current limiting other than blowing its fuse or tripping its breaker (on the amplifier) pending on which model you own. The QSC RMX 2450, 1850, 1450, in addition to 850 is QSC’s bottom of line series amplifier. The Peavey CS series was Peavey’s top of the line series. A brand new CS 800 cost $700. A brand new RMX 2450 was $700 before Behringer EX 2500 came about and QSC dropped the price to $600.00 QSC designs the most current efficient line of American amplifiers available on the US market. This is why QSC is so popular amongst small providers for they can plug them in a 20-A or even 15-A, 120-volt receptacle and have no worries about tripping a breaker. Try to rent the old Crown Macro-Tech 2400 and, compare the power consumption to the QSC RMX 2450. The Crown Macro-Tech 2400 is class A/B and will show you how efficient Class H is compared to Class A/B is from a current draw perspective. Best Regards, |
Tweet
