Opinions on MT130 |
Thomas Hosker
Registered User Joined: 20 June 2012 Location: East Sussex Status: Offline Points: 493 |
Posted: 07 December 2014 at 4:02pm |
Looking for people opinions and any general info i can get on the MT130 top.
Would that throat arrangement give a nice wide dispersion. What the realistic frequency range for the 12" section? Most importantly how does it sound? Cheers |
WWW.T8Audio.Com
bass*en*mass
try the search function?
recent thread about it.. Nuclearbass on here had some for quite a while if you want first hand experiences etc., lots of info about them on here already ;) |
kevinmcdonough
This is a hard one, not a massive amount of people have built them. There's a fair bit of info on their construction etc here and on FSP, but not a massive amount of actual listening experience, and comparisons to other speakers. At leas that I've seen.
The one, main person who did seemed to suggest that they sounded good but were very long throw, to the point of hardly sounding switched on up close but the sound developing further away and carrying really well. There was some question though that he adapted the box slightly to be square bodied rather than trap (so rear chamber may have changed a bit) and that the driver he used may not have been ideal, may have been a bit more of a reflex driver. Would be good to get a properly built set and compare them to an MT-122 and a commercial horn loaded cab or two, get a much better idea of what they can do. People on Marc O's (the designer) french forum seem to love them though. k |
Thomas Hosker
I gave that a go Bass but we all know the search forum usually comes back with a load of crap and ancient threads. I was looking for peoples actual listening experiences on them as Kevin said.
They look super easy to build do i think ill just knock some up and give them a test, I must admit im not to happy about them being super long throw but ill try some different drivers and see what happens. Looks like the ideas is worth a go. Thanks guys |
WWW.T8Audio.Com
bass*en*mass
are you on super tight budget? Whats the goal with these?
ceharden
In general, this type of cabinet is not designed for wide dispersion applications unless you're running 2 or 3 per side. They are narrow frequency range, narrow dispersion but very high efficiency within those constraints.
kevinmcdonough
hey
yeah just reading over your original post its not wide dispersion at all, 30 degrees I'm sure. Designed to be used in groups of three really to cover a large area. k |
MR-FIZZLE-89
Registered User Joined: 03 February 2012 Location: Sutton Bridge Status: Offline Points: 76 |
I'm also very interested in this. For a while i've been debating between these or the tried and tested MT121.
Mattias Andersson
Registered User Joined: 24 August 2010 Location: Sweden Status: Offline Points: 30 |
I would also like to know more about those mt-130 before I'll build some.
