  New Posts New Posts RSS Feed - Output transistor number in design
fossil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossil Quote  Post ReplyReply Direct Link To This Post Topic: Output transistor number in design
    Posted: 23 March 2017 at 5:36pm
Just got a cheapo Soundlab G097A which is basically as cheap as they come but inside it has 12 yes 12 NPN PNP devices (2SA940 and 2SC2073) paired up. With a spec output of just 1.5 amps each, why on earth wouldn't you just use say 1 complementary pair per channel - at a higher rating, given how cheap they are to buy ?
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2017 at 6:47am
Edit - I didn't read the question properly
Edited by patryk1305 - 24 March 2017 at 6:55am
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2017 at 7:10am
spreads the heat over more transistors instead of a few highly rated ones? Just a uneducated guess anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2017 at 10:07am
They got a deal on the smaller devices? For example, they use them as drivers on the bigger amps, so have plenty to spare. Decisions like that are always down to economics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossil Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2017 at 10:12am
Given how crappily cheap it is I suspect Earplugs hit it. The 2 PSU caps are 35V 3300 feeding the whole lot. When I switched it on first time one went phiz and filled the room with white smoke. Even got a pic which i'll post when i know how. Anyway, I bought it for the case as a project but before I gut it I will hook it up (change the caps first!) and listen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossil Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2017 at 10:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossil Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2017 at 12:29pm
This was the offending fella
This page was generated in 0.516 seconds.
