  New Posts New Posts RSS Feed - P. Audio C18-650el in PD1850 horn
mylesound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylesound Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 3:50pm
would it be worth it to put it in a 1850 with all that compression only feeding about 600w or would a 186 cab RCF loaded AT 1000 watts get Greater SPL?
Edited by mylesound - 26 March 2008 at 3:51pm
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 3:57pm
He already has the drivers tho. I think the question is 1850horn or 186horn......?
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 3:58pm
I will rether try 186horn though
www.aggressiveaudio.co.za
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2008 at 4:49pm
I would go with 186horn with the C18.
Pozest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pozest Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2008 at 6:51am
Cool thanks,guys 186horn it is....
Can you feel the BASS!
bmf2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmf2 Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2008 at 7:03pm
Regarding the xmax. Doesn't paudio measure in one direction giving a lower figure than other manufactuers. I seem to remember this being discussed before.
I also am considering this driver in a 186 cabinet. I'm very interested in the results if anyone has tried it.
You say it's too loud-I say your hearing is too good
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2008 at 7:52pm
xmax is always one way but seem to remember p-audio measuring in a way that gives a 25% lower figure than actual. mircea bartic can probably clear this up.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2008 at 9:09pm
http://www.speakerplans.com/forum/forum_posts.asp?TID=3747
Theres loadsa other threads aswell that mention it, i know i have discussed it with Mircea.
Search!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2008 at 9:16pm
Paudio Xmax - a thread i started
Regarding a design of mine, but it might still be relevant
heinrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2008 at 2:44am
so Jake, as Mircea states, it is "possible" to use the C18-el in the 1850 or 186 horn.......?
conclusions pls......
Edited by heinrich - 01 April 2008 at 2:46am
.....power is nothing without control....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2008 at 8:12am
Ha! I specifically didnt say cos i don tknow LOL
All i know is, dont be too scared by the low xmax on Paudio.
If anyone has the parameters for the 186 horn (I dont have time to work right now) then i'll model it and get Mircea opinion on the results if possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2008 at 9:46am
Cool
but somehow TDA let the C18-650el drive his WSX.....
..................hoooo!!!!! it's summer here...
heat hits 35deg.........!!!!!!
