p audio - to recone or replace |
Post Reply | Page 12> |
semtexsystems
Registered User Joined: 10 August 2005 Status: Offline Points: 31 |
Posted: 13 August 2007 at 8:39pm |
hi!
ive been searching for a tutorial of some sort regarding reconing my 2x paudio p180 2242 i use them in ES18-BPH but i cant find much info on it.
ive confirmed that pap have a the kits but i dont want to spend £170 on them only to find i am unable fit them.
has any one reconed any of thiese or similar? if so any tips?
thanks Ben
www.semtexsystems.co.uk
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
I'm presuming that is £85 for each recone Otherwise it's time for different drivers. There is a B&C tutorial around for reconing. I'm sure someone was selling 2x original jbl 2242's for £200, on here somewhere. |
semtexsystems
yes £85 for each!
had a look at the b&c tutorial. not too sure if i want to gamble the money
cant find the jbl's! think they must have sold!
are they the same driver? will jbl recone kit fit & be any cheaper but be of equal quality?
thanks
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
The first thing you need to find out is whether the kit is complete. Is the voice coil already fitted to the cone and does it have shims included. If so, then it isn't rocket science. The most important thing is to clean every bit of the old cone off the chasis THOROUGHLY. I always put tape over the voice coil gap first, so I don't get any more crud in there. Then when the rest is cleaned off, take the tape off and do the voice coil....... and it's REALLY important that you get this clean. Provided you follow the instructions carefully there is nothing to fear.
levyte357
What are T/S specs required for the cab?
I "think" the new Celestions FTR's are supposed to be superior replacements of 2242's or similiar driver but better performance.
And available from some places for £110 each *NEW*.
semtexsystems
i tried to get my head round t/s specs and winisd a couple of years ago then i took a chance and built 2 ES18-BPH, there not the recomended driver for this cab (paudio sd18 is recomended) but they do seem to work well!
would the void v1200 work in this box? if not what are the important paramiters to stick by
thanks ben
levyte357
I suggested Celestions because if they are suitable, they are not much more than your recone scheme... Best bet is find which drivers people have used in this cab with success, and buy best you can afford. |
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
I agree with Levyte here, it is fairly easy to recone speakers but if you dont want it on your mind that perhaps you didn't do it right, then get the Celestions FTR's there the recomended driver and they would sound good....
CELTIC SUBSONIC SOUND SYSTEMS
j_0_e
Young Croc Joined: 18 March 2007 Status: Offline Points: 659 |
no, it was 200 each lev...
levyte357
Yeah that was very recently.. But when I was selling my 2241's, Another dude was selling 2242's, saying they were filthy in his Gsub.
j_0_e
oooohhhh, my bad...
semtexsystems
The voice coil is fitted to the cone and shims are included so i have decided to go ahead with the recone!
Ive had a look at the b&c tutorial and i think all should be well.
What do you use to clean all the old cone/glue off the chassis? will a stanley blade do? or will i need some thinners or something?
Thanks Ben
