  New Posts New Posts RSS Feed - PA (subs) for live techno/dance band
christiana_ahm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote christiana_ahm Quote  Post ReplyReply Direct Link To This Post Topic: PA (subs) for live techno/dance band
    Posted: 17 January 2012 at 11:39am
Hey speakerplans. Ive bin looking alot around your forum, but designed to sign in, cause i need some help.
I play in a partyband, that plays all sorts of bass heavy music, but in a live setup. We have an old PA that we use for rehearsal, but we need something bigger that we can bring for gigs. Our gigs are primarily 200-500people. In 200-300^m2 rooms.
1. I need alot of bas, especialle to mic the kick drum, and a bit of bass guitar aswell.
2. I need to transport it around. So large horns are out of the picture.
3. I dont need long throw.
4. I don't need super low bass (its a live setup) Lowest frequency generetad would be the 41hz from the bass guitar (E)
My thoughts were a pair of double 18" (reflex or?), and then buying some primade fullrange tops with a 15" bass/unit, to be able to reach the subs without to much of a gab.
I already have a x-over (Dba DriveRack PA), but i need everything else. The budget is around 3500 euro.
So the question is which subs to build, and which tops to buy (or build myself, though i would prefere buying these).
digitallake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote digitallake Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2012 at 2:02pm
Hi
If you don't need long throw then direct radiating / refex bass bins would be the best option by the sound of it, you would get better quality close up. Double 18's however are really heavy and difficult to move around. You may be better building single 18's or 15's for bass, and then buy the mid+tops you mention, but personally I would go for a 12" top because better for vocals ( for example EV SX300, or better) the dbx driverack would be fine for that setup.
Hope that helps, Jim
Post Options Post Options   Thanks (1) Thanks(1)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2012 at 2:24pm
if go for four x 15" reflex subs (singles so easier to move, and can use just a pair in a venue).
B&C sub15 design maybe?
Midtop, a decent pair of 12"+comps will do it fine, something meatier than SX300, from the olderschool EV QRx112/75's, to newer stuff like the EV ZX3 - driven with decent amps and a nice processor - say EV CP3000 bass CP2000 midtop with DX38 processor... lovely little compact great sounding rig!
As you may have noticed, i do have a thing for EV kit for these sized jobs - i think its very well priced for performance and quality in this portion of the market, i prefer EV over the similar sized turbosound opus ect ect...
Depending on your budget might be worth going for an integrated active rig designed to work as a whole, the active Fohnn Xperience rigs are by far my favourite live rig of this size range, sound incredible and such a high output in a small package. They dont come cheap however but are worth every penny if you have it
Post Options Post Options   Thanks (0) Thanks(0)   Quote digitallake Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2012 at 2:43pm
Yes very much a fan of EV myself :), which is why I used the SX300 as an example, but yes maybe go for something a little meatier. I still use the original S-200's.... 6 of them, and a DX38 on my main system!
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2012 at 2:49pm
for 200 people 4x18"/15" subs maybe be enough, but for 500 you would need to double that...
i would look at 2nd hand market and DIY because 3500 isnt much money for a 500people gig...
Dref View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dref Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2012 at 4:12pm
At kikke på DBA, GulogGratis og lign. Efter en brugt halfront er nok et godt sted at starte, der er af og til noget der tilsvare det du efterspørg, til en fornuftig pris.
Post Options Post Options   Thanks (0) Thanks(0)   Quote christiana_ahm Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2012 at 8:55am
So sounds like reflex are the way to go. I longest throw will be around 20-30 meters
Our current PA is using to old JBL 18" (2240H) reflexes for subs, and that doesn't deliver nearly enough SPL, so we wan't something that will deliver a descent bit more than that. Just so you know what we are used to.
Isn't double 18" the cabs where you usually get the most spl/cubic meter?... I mean, 2 drivers placed in a "rather" small box? or is 4 single 18"s just as good?
Kind Regards Christian
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2012 at 12:45pm
8 x single subs would be my favourite choice, reflex is good, but for techno...bandpass horns like es18/usb/turbosound will kick hard!
Post Options Post Options   Thanks (0) Thanks(0)   Quote christiana_ahm Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2012 at 3:44pm
okay... i think we have a budget to go with four decent, 18" speakers (pd186 or similar?)
How would the a pair of g-subs compare to a pair of bandpass subs like the usb or turbosound tsw 7-18?
And thank you all for your help
andycw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andycw Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2012 at 4:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote christiana_ahm Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2012 at 7:28pm
Ive heard them aswell... pretty impressed, but the budget was 3500 euro not punds unfortunatly.
How about the comparing g-sub vs. usb/turbosound and so on... what difference does it make? throw? frequency spectra?
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2012 at 9:00pm
Reflex subs (such as gsubs) will generally cover a wider frequency range than a bph (usb/es18/turbo). The bph will typically be more efficient (louder) though, and do great things for kick drums. With your band you probably won't miss the lower frequencies anyway.
Throw is a myth really. If you make it louder at the source it will be louder 20 metres away.
Great video clip, your gigs look fun!
Blahblahblah
Forum Software by Web Wiz Forums® version 10.11
