Passive crossover attenuators |
Post Reply | Page <123> |
Author | |||
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 699 |
An X15, between a SN15B and BMD450.
studio45
If you're adding an L-Pad, then you have the opportunity to add some EQ as well, to flatten out the top end. BMD450 starts rolling off at about 11kHz and can benefit from some boost above that.
To achieve this, you would add a series LCR (inductor, cap, resistor) string in parallel with the series resistor of the L-Pad. The LCR string is sized such that it presents a low resistance at some very high frequency, so it allows more HF to "bypass" the L-Pad and go directly to the driver. By doing this you can run the box in situations where an EQ is not available, and still have good high frequency response. The components are quite small. A good starting point for a low-Q boost centred at 15kHz would be 60uH (0.06mH) in series with 1.9uF, taking the assumption that there will be some DC resistance in the coil - wind it with fine wire, it doesn't have to take much power. This will start to boost from about 11kHz and continue to act until about 18kHz. The amount of boost of course depends on how much your L-Pad would have taken off, so in your case about 5.5dB.
Risc_Terilia
Great thanks for the advice and explanation.
ceharden
A good starting point would be an 8.2Ohm resistor in the R2 position then experiment with different values of capacitor in the C3 position (which puts it in parallel) to get the HF lift desired. Start with something like 2.2uF. You may need to remove some shorting links which have most likely been added to the reverse of the board.
ceharden
Attenuation networks are far from an exact science and you actually have to change the resistance a fair amount to get an audible difference. Trial and error is likely to be the best approach and you'll probably still end up doing the fine tuning with some EQ depending on the venue anyway.
cravings
Risc_Terilia
Which value should I use for the resistor in the LCR plesae?
studio45
Thanks(1)
There is no single answer for that. It depends on how much boost you want. For the maximum possible boost use no extra resistor, just rely on the inherent resistance of the inductor. For less boost, use a larger resistor. When the value becomes more than twice as large as the L-pad's series resistor, you will be adding very little boost. So that is your window of useful values - zero to 2x the L-pad series value.
The resistor also affects the Q or frequency range of the boost. Small value or no resistor will give the narrowest boost the L and C values will allow, larger values will broaden the effect (but reduce the amount of boost, as discussed above). Again, this is a matter of taste and you can choose any Q that sounds good. There is a very useful "RLC calculator" on the Iris Strassacker website here.
Risc_Terilia
That's some awesome knowledge thanks very much. I actually tried a broad 11k boost but to be honest it really sounded a lot like before I had the L-Pad in at all but I'll play about with the parametric and try to mirror the settings on the calculator. Really can't thank you enough for all your help
Andy Kos
This board doesnt use an L-Pad, you can use the resistors from the chart here:
They are 2 series resistors, to give a variety of configuration options, the guide above is the most basic. You can also just use R2 for attenutation, and make R1 large (20 ohms or more) and fit a polyswitch of appropriate size into PTC1. When the power to the tweeter goes too high, the polyswitch goes open circuit, adding R1 into the circuit. This acts a bit like a harsh limiter if you overdrive your HF, ducking the volume by several dB for a while until the power levels drop. As Chris mentions, you can put a capacitor in parallel with R2, and 2.2uF is a very good starting point. This gives a 6db/octave lift to help balance to frequency response, giving a hi-shelf boost. |
Andy Kos
We have published the attenuation information online, I think at the time you made the purchase we were still finalising the pdf. It is now included with all crossovers. We have started phasing out the old boards, which had been in use for probably 20 years or so, and we're updating the board to take higher spec components for higher power handling, also to make them more versatile. Mike Keene (Convair) who made the Link Dynamics crossovers decided it was time to hang up his soldering iron and retire, so we have taken over the manufacturing of these crossovers. As the old stock runs out, we will replace the boards with new options, the first step was to add attenuation (sadly lacking in the old boards) and in the future we will be putting together more variations of customisable crossovers. |
Risc_Terilia
That all sounds really positive Andy. I didn't mean the lack of paperwork to read as a critisism - I wouldn't expect a product like this to have total hand holding :)
