  New Posts New Posts RSS Feed - Passive Crossover Padding
Biggus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Biggus Quote  Post ReplyReply Direct Link To This Post Topic: Passive Crossover Padding
    Posted: 20 February 2012 at 1:42pm
I'm about to install a passive crossover (Eminence  PXV2-3K5 Two Way Crossover @ 3.5 Khz) into a cab but I'm wondering if my HF driver will need padding down? I've read on here that its quite common to pad them down as there sound to loud/harsh compared to the main driver. is this info correct? I've only ever used passive crossovers so could turn it down at the amp.
I figured if I to knock off 6db I would have to put 8 ohms across  and then 4 ohms in series. calculadted with this tool but the resisters have to be 25watt. where would I be able to purchase them from?
L-Pad (Driver Attenuation Circuit) Designer / Calculator
http://www.diyaudioandvideo.com/Calculator/LPad/
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2012 at 2:38pm
You need to listen to the cab first and then decide. It would depend on the sensitivity of the woofer - and your taste in music! Most decent electronic hobby shops will have the resistors.
Edited by Earplug - 20 February 2012 at 2:38pm
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2012 at 4:26pm
The best place is www.rapidonline.com but they only come in certain values if you go for 6.8 ohm and 4.7 ohm that will give you about 7dB attenuation. Get metal clad 25 watt for up to 400 watt or 50 watt for over 400watts.
Or go for 10 ohm and 3.3 ohm which will give you 5dB as near as damnit. Here's a link to the page
http://www.rapidonline.com/Electronic-Components/Aluminium-clad-wirewound-resistors-65217
Edited by markie - 20 February 2012 at 4:28pm
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2012 at 7:26pm
You can experiment with lower power resistors until you get it sounding right then built a final L-Pad with big ones.  25W metal clad should be fine for almost all applications.  If you're crossing over at 3.5kHz you may get away with even lower power than that.
Also don't get hung up on getting the impedance spot on, whether the final impedance that the crossover sees ends up being 7Ohms or 9Ohms, you won't hear the difference! The impedance of the driver will vary by a lot more than that!
I've used the 6.8 and 4.7 combination quite often.  Incidentally you can also swap those two values round and get slightly different attenuation values but still keep the impedance fairly constant!
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 9:34am
The best way to determine the values for a pad is to put in a real L-pad and adjust it until it measures good and sounds right. I use a nice 50W Fostex L-pad for this purpose.
Then remove the L-pad, measure the series and parallel resistances, buy the closest values (starting a bit high if need be), and then trim with a higher value to get it down where you need it to be. The trim resistors are usually 10x higher in value than the required value, and thus only need to be a smaller wattage type.
Instead of guessing at the wattage, let's calculate what it needs to be. I've had to use four 25W units in series/parallel (100W total) to handle the heat in a typical two-way network at 1.6Khz and the resistors still get hot enough to melt the solder and burn anything that touches them (and that was with an amplifier only rated at 250W/8Ω driving above 100hz).
Let's make up some examples.
6dB pad with 40V input, 4Ω series, 8Ω parallel. Both resistors would have 20V across them, so the 4Ω would need to be a 100W type, and the 8Ω would need to be a 50W type.
9dB pad with 40V input, 5.16Ω series, 4.40Ω parallel. The series resistor would have 28.3V across it, the parallel would have 14.14V across it. The series resistor would need to be 155W, the parallel would have to be 45W.
12dB pad with 40V input, 6Ω series, 2.68Ω parallel. The series resistor would have 30V across it, the parallel would have 10V across it. The series resistor would need to be 150W, the parallel would have to be 37W.
When I decide to leave and L-pad in a design for user adjust-ability (bad idea in general) I generally use a fixed pad in front of the adjustable one. Example: a fixed 6dB pad followed by the L-pad that would be adjusted to -2dB~-4dB. This allows the use of a 50W L-pad  for a total of about 9dB of attenuation, which would normally require a 200W L-pad (unavailable).
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Biggus Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 1:35pm
Cheers all for your responses. I've not got my crossovers yet but I was just wondering what I could do to turn the tops down if need be. I will have a gig a few days after when I get them so I wanted to be prepared just incase I have to pad them down, due to resistors been relativley cheap I thought it would be handy to have them ready just in case I need them. This is the first time I'll be using passive crossovers so thats why I asked if it were quite common to pad them down? As most of you say it be worth giving them a listen before hand but I'll have very little tiem before I take them on the road. I'll be pumping 400watt though them so would 25watt resistors be OK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 1:44pm
The difference in price between 25 watt and 50 watt resistors is about 25p each. Ask youself what you would prefer to do either spend an extra couple of quid on 50 watt resistors, or possibly have the crossovers pack up in the middle of a gig.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Biggus Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 1:50pm
Markie - you are correct, I'd rather just spend the extra 25p on them, didn't realise what the price diffrence was better to be safe then sorry :-)
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 1:53pm
Bear in mind also that 25- and 50-watt metal clad resistors are rated for use with a heat sink. If you don't use a heat sink, drop the rating by half.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 1:54pm
Rapid on line are very good, if you order now chances are they'll be with you in a couple of days. If it were me I would buy enough to do say 2 each of 5dB and 7dB then you can try them. The spares will doubtless come in handy for the future.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2012 at 2:07pm
Why not build multiple l-pads and use a rotary switch to select which you want to use? And then after a few uses you have the option to take out the switch and keep the level you use most/like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Biggus Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2012 at 1:04pm
Resistors have been ordred from Rapid! cheers all for your help
Forum Software by Web Wiz Forums® version 10.11
