passive crossover |
Post Reply | Page 123> |
godge
Young Croc Joined: 07 July 2010 Location: Gloucestershire Status: Offline Points: 597 |
Posted: 10 February 2016 at 10:20am |
Ok so this isn't PA its a hifi build but I haven't got the greatest idea on passive crossover builds.
Here's some info on my build specs. 6.5inch driver - B&C 6ndl38 Fountek Ribbon NeoPRO 5i ribbon tweeter. Box dimensions 380 (h) 220 (w) 300 (d) It's a rear ported design, Looking at having the 6.5inch tuned down to about 45hz with the box design. The ribbon will be crossing over at the recommended frequency of 1500hz with a 18db slope, and thats about as far as I've got, I don't have any real idea on the building of the crossover to achieve this. Any help would be greatly appreciated |
all bass
There are some crossover calculators on the net, they should get you in the ball park. After that, it's a lot of measuring and tweaking.
Calculator, in German though... |
godge
My main worry is that I don't want to ruin the ribbon tweeter accidentally but hopefully the calculator will put me in good stead. Been a while since I've done a build but looking forward to it again
Steve20131
Registered User Joined: 28 July 2013 Location: Northants Status: Offline Points: 411 |
Use an old speaker to test first
_djk_
I would use a 1.5Khz 18dB Butterworth design assuming a 7Ω impedance and you should be fine (for the ribbon).
The B&C will probably require a notch filter at 4.2Khz, in addition to the 1.5Khz crossover. I don't think the 72hz Fs will like being tuned to 45hz very well. |
djk
godge
How low do you reckon I would be able to achieve with port tuning etc
Andy Kos
Crossover calc to get you in the right region:
http://www.speakerwizard.co.uk/1st-and-2nd-order-crossover-calculator-and-response-simulator/ plots frequency response too. If you need help with any components drop me a PM |
godge
Cheers Andy I'll keep you in mind when looking for components. Already got the b&c drivers from you a while back
stevie
Registered User Joined: 16 March 2008 Location: Dorchester Status: Offline Points: 425 |
Somebody needs to warn you that it is impossible to design a decent passive crossover without a lot of knowledge and experience. You will also need proper measuring equipment - otherwise you're working completely in the dark. If you're just going to mess about for fun, fair enough. But the idea that you can design a crossover using an online calculator is ridiculous.
snowflake
put a zobel on the woofer and an l-pad on the tweeter and you can assume fairly constant impedance to design the crossover. 4.5kHz is way above the tweeter resonance so you could cross a bit lower so the rising response of the woofer isn't such an issue. getting a notch filter right without measurement is tricky - unless the response is terrible you could just correct it with a bit of eq - most rooms and source material will need eq anyway.
stevie
This is a sure way of making £600 worth of drive units sound like garbage. Seriously - get a miniDSP and another power amp and go active.
godge
I have though about going active the more I look into this, passive crossover seems like far too much work and research, but then it is also such a hassle having a separate dsp etc, ultimately I do want a nice sounding pair of bookshelf speakers that I can just run off my amp at home
