Passive high pass filter for tweeters |
Post Reply | Page 12> |
dnbpc
Registered User Joined: 18 March 2010 Location: Manchester Status: Offline Points: 381 |
Posted: 04 February 2016 at 1:37pm |
If I wanted to make a passive high pass filter for a tweeter box @ 10khz is it as simple as adding a capacitor of a certain value to the circuit or would I have to make a complete crossover? If so can anyone give me a basic explanation of where to start?
stevie
Registered User Joined: 16 March 2008 Location: Dorchester Status: Offline Points: 425 |
It's more complicated than that but, yes, you could make a start by adding a capacitor in series with the tweeter. A film capacitor of around 2.2uF should work with an 8 ohm tweeter. Get 3 values 1, 2.2 and 3.3uF and try them out. The Loudpeaker Design Cookbook is very good as a primer on this kind of thing.
10kHz isn't a critical area - so it could work at a pinch. Also try swapping the phase of the tweeter in circuit to see what sounds best. |
dnbpc
Cheers I'll order a few different value capacitors and have a mess about, I'll make sure to check out the book as well.
Am I right in thinking that if I wanted to increase the slope of the filter I would need to add a resistor as well? |
stevie
You'll need to add an inductor.
odc04r
Not necessarily. A first order high pass can be made using a single series capacitor. Start simple.
stevie
You'll need to add an inductor (rather than a resistor) if you want to increase the slope of the filter.
Edited by stevie - 04 February 2016 at 6:08pm |
_djk_
I would not use a crossover with less than a 12dB slope.
1.5µF + 0.4mH = 10Khz Q=.5 (Linkwitz/Riley) |
djk
dnbpc
Right I think I've got a better understanding, so to get a 10khz 12db slope I would connect a 1.5µF capacitor and a 0.4mH inductor in series before the tweeter?
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
The cap goes in series with the tweeter but the inductor goes in parallel. This will give you an idea:-
http://www.diyaudioandvideo.com/Calculator/SpeakerCrossover/ Edited by markie - 05 February 2016 at 4:26pm |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
There's lots of crossover calculators out there, I'd do a 18/db slope one, takes a few components but for a electronic circuit it's very simple, components are big though, use at least 100V components, probably more, depending on power, so they don't blow up.
MarjanM
Crossovers are not made with calculators but with measurements.
Calculators assume a flat line response which never is. What is below the tweeter? Is sensitivity matched to the rest of the components?
tv00
You still have to calculate the xover rather than connecting random components!
You're right, sensivity has to match +impedance has to match the xover, also a hard part is to get a smooth transition, drivers might couple /decouple at xover as phase also gets twisted. I really don't know too much about this, but I saw a couple of interesting posts about this. |
