Passive mic split |
soundguymatt
Young Croc Joined: 25 August 2009 Status: Offline Points: 688 |
Posted: 26 August 2016 at 10:17am |
How does one wire a passive mic split? am i right in thinking that for 2 identical consoles, or stage boxes, a simple Y split on each input is sufficient? wired 1-1-1, 2-2-2, 3-3-3?
Matt |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
I'm guessing you'd want some form of isolater incase one of the desks sends phantom power.
ceharden
It's pretty normal to do 2 or 3 way passive splits without isolation.
Liteworks
Registered User Joined: 29 April 2008 Location: Cambs / Luton Status: Offline Points: 383 |
Our 32way splitter is wired as 32 individual y-splits. No issues thus far.
-m |
Danny A
Registered User Joined: 30 May 2009 Status: Offline Points: 444 |
one of the desks (monitor world), will be almost certainly be sending phantom power for condensers and DI's. An active split is usually only required for broadcast etc
Earplug
Passive split is no problem - just make sure that only one desk in the chain sends the phantom power!
fatfreddiescat
You may need to lift pin 3 on one of the splits to prevent hum loops, if you do, you could add switches, I would lift the mon side of the split as you will always be using the FOH split.
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
I've used and manufactured many multicores that use y splits with out any issues.
Also made some with a sowter transformer on every channel they get very expensive.
In the Truth there is no news, and in the News there is no truth
soundguymatt
Thanks guys :) I was sure it would be ok (active transformer would be lovely but £££)
Matt |
