  New Posts New Posts RSS Feed - Passive Mod
Passive Mod
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Topic: Passive Mod
    Posted: 08 February 2017 at 1:22pm
Hi, below is a pic of a 2.2k x over from an NJD cab. I'm using same hf, CDXi1545 but slightly more efficient 15. The top is a fraction too, "dumbed down".  Not a lot, just a bit. Blue and brown wire go to top. Am I right in thinking if I lose one of the double stacked resistors I might gain a little?
Thanks as always
dlyxover View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 2:14pm
You don't need to loose a resistor you need to replace both resistors in the l pad to give less attenuation.
below is a link with some useful info and a list or resistor values
In the Truth there is no news, and in the News there is no truth
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 10:23pm
It looks like a pretty basic 12db/slope LC xover but the resistors could be wired in several ways. Could you draw out the diagram of the circuit with component values and then I could give you an exact answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 10:54pm
Will do
